Question about Hitachi 51F59 51" HDTV Projection Television
Hitachi 51F59A Color/Dark problem
Our Hitachi 51F59A rear projection screen television is 12 1/2 months old. While we were watching a program, the picture turned very dark and a blue color took effect. All program viewing is now dark similar to when the brighness is turned very low and the color within the picture is blue.
What could the problem be and will Hitachi back up the product?
  • 5 more comments
  • sailoften Mar 12, 2008
    screen turns totaly green you must turn it off then back on to regain the picture
  • Anonymous Oct 04, 2008
    I have the green screen problem constantly. As mentioned I simply turn my TV off and then on again, ANNOYINGLY! But now, once again, I have the blue/dark screen situation. It happened before but went away so I ignored it. Now it's back again and I see everything in very dark blue.
  • mattmullican Oct 04, 2008
    I have the same problem. It went away now it's back. Can I do anything to fix it? Please let me know.
  • Anonymous Nov 08, 2008
    SAME AS ALL THE POST BLUE PICTURE AND DULL
  • bmarlene1 Nov 17, 2008
    My Hitachi tv was damage after a electric storm
  • soxgirl77 Nov 28, 2008
    I have been having the same problem. The screen will go completely black with the sound on in the background fine. Usually lasts a minute or so...or the screen will distort like a blue black color.( It did this while I was playin an Xbox 360 game) It goes away if i turn the tv off and then on again. My tv is 3 or 4 years old and i'm wondering if it's even worth it to fix it.
  • matygayle Dec 24, 2008
    My screen has gone to a dark and greenish color. Tried reseting everything and doing Magic Focus. Nothing?
    Problem Solver:
  • 14 Answers
The 51F59 is notorious for this problem. The pins on the RGB tubes tarnish over time and the connection starts failing, leading to a dimmer picture. To fix the problem, unplug the set. Remove the bottom panel by carefully flexing the outside edges on either side to pop it out of the connectors. Once removed, loosen the top left and right screws holding the center press-board cover in place, then remove the other screws completely. Lift the cover and remove it. Within the chassis the RGB tubes are visible. At the base of each is a circuit board with the tube socket, plugged into the tube, held in place with a clamp. On each tube, loosen the clamp screw then gently pull the circuit board/socket downward to remove it. Gently clean the pins on the tube with a soft cloth and rubbing alcohol, being careful not to bend them. Then re-install the board until firmly seated in the socket, and remove the board. This should be repeated a couple of times to insure the pins and socket connectors are free of tarnish. Finally, re-tighten the clamp and move on to the next tube. When finished, replace everything in reverse order.
Posted on Dec 29, 2015
Could be the blue CRT shorting out. I had the same problem but with red. Eventually it shorted out completely. If it is only 2.5 month old it should still be under warranty and they will fix it.
Posted on Feb 27, 2008
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
We have a Hitachi 51F59A which has stopped producing a sound output. We have had this rear projection television for 18 months. What part is needed, and is it covered under Hitachi warranty?
would you like to sale it. you can call at 419)741-7350
I am looking for a 51 inch high definition hitachi television model no:51F59A.
Wanted A Hitachi 51in for Parts
Jul 25, 2008 | Hitachi Televison & Video
51F59A model hitachi rear projection tv
You may need to set your screens look at the picture when you have a real dark background if there is faint lines in the picture then the screens should be set correctly
Jun 11, 2008 | Hitachi 50V715 50" Rear Projection...
51f59a hitachi projection color televison
Philips has a projection cleaner. I wouldn't use adbrasives like alcohol or windex. try www.vancebaldwin.com or MCM electronics corps
Apr 04, 2008 | Hitachi 51F500 51" Rear Projection...
51F59A
TV: Viewing Screen RPTV - damage and maintenance
http://www.hdtvmagazine.com/forum/viewtopic.php?t=6547
Mar 21, 2008 | Hitachi 51F500 51" Rear Projection...
HITACHI 51F59A PROJECTION COLOR TV
we have hitachi 51 inc projection tv model 51f59a for 2 yrs. we got problem adjusting the colors the screen is reddish. pls solve this .
Jan 08, 2008 | Hitachi Televison & Video
Hitachi 51F59 51" HDTV Projection Television Logo
886 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
