Photo ink 58 do i put it on the right side and what other ink cartridge do i need to use
What ink cartridge do i need with 58 photo
  • bigbadbrenda Feb 21, 2008
    do i need to use 57 or 22 with 58 or can i just use 58 only
    Scholar:
  • 41 Answers
Normally, you keep the regular tri-color cartridge in the place it already was.. You should be taking the black cartridge OUT and putting the 58 Photo cartridge in...
FYI.. the 58 photo cartridge provides you with LIGHT magenta, LIGHT Cyan and a PHOTO Black -- which are supposed to give you truer tones and 'half-tones' for shades and nuances in color (like different grades of blue in the sky). The Photo black helps the photo not look "green" on black areas when there is a reflection on the photo... (with regular ink, when you get a reflection off of the shiny paper you often see a green-ish like color and it looks rather odd... the photo black stops that.)
Maggie B
Posted on Feb 21, 2008
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
Mar 24, 2011 | HP Deskjet F340 All-In-One Printer
I need to remove/replace cartridge,i dont know how?
Hi!
This link guides you on how to replace the cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&product=79477
Replacing the print cartridges
  1. Turn on the power.
  2. Lift the print carriage access door on the front of the unit, just above the output tray. The print carriage will move into the middle of the access area. Figure 1: Raising the front access doorc00004385.jpg
  3. Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch and then pulling the lower section of the latch forward. Lift the latch.
  4. Grasp the sides of the ink cartridge and pull the cartridge out to remove it. Figure 2: Removing the cartridgec00004386.jpg
  5. Remove the replacement cartridge from its packaging. Touching only the black plastic, remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tapec00004387.jpg
  6. Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage as shown below. Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch). To install the optional photo cartridge (HP 58) for six-ink photo printing, remove the black print cartridge (HP 56) and insert the photo cartridge (HP 58) instead. Figure 4: Inserting the cartridgec00004388.jpg
  7. Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur. Figure 5: Latching the ink cartridges in placec00004389.jpg
  8. Close the print cartridge access door. Figure 6: Closing the access doorc00004390.jpg
  9. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Nov 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Ink cartridge 56 and 58
the printer itself recognizes cartridges
hp 57 print cartridge
hp 58 photo inkjet cartridge
and hp 28 inkjet print cartridge
any other cartridges will be of no use for this specific printer
Oct 31, 2009 | HP DeskJet 5550 InkJet Printer
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP7660 Photosmart Printer
It comes with HP #57 (C6657 A)—Tri-color print cartridge and HP #56 (C6656A)—Black print cartridge and the 56 must always be in there (the black one) but acceptable replacements for the color one are as follows: HP #58 (C6658A)—Photo print cartridge I suggest for the best photos use 58 and 56.
Feb 28, 2009 | HP PhotoSmart 7660 InkJet Printer
Cannot get ahp58 ink cartridge to fit a hp2410 printer,the box that it come in said it would fit; how do I get it to fit?
The #58 cartridge goes into the right side...remove the black cartridge and insert the #58 cartridge. This give the printer a wider range of colors when printing photo.
Nov 22, 2008 | HP Office Equipment & Supplies
How to change black color inkonHp2175all in one
Supported HP ink cartridge part numbers The HP PSC 2100, 2170, and 2200 all-in-one series products use the ink cartridges listed in the table below. The HP 58 tri-color photo ink cartridge replaces the black ink cartridge for six-ink photo printing. Ink cartridges Part number HP 56 black ink cartridge (19 ml) C6656A HP 57 tri-color ink cartridge (17 ml) C6657A HP 58 tri-color photo cartridge* (17 ml) C6658A HP 27 low capacity black ink cartridge (10 ml) C8727A HP 28 low capacity tri-color ink cartridge (8 ml) C8728A * Replaces the black ink cartridge for six ink photo printing and includes cartridge holder. Replacing the ink cartridges The power must be turned ON to the all-in-one or the print carriage will not come to the center.
  1. Locate and raise the print cartridge access door on the front of the unit, just above the output tray. The print cartridge carriage will move into the middle of the access area. Figure 1: Raising the front access door and the ink cartridge latches c00224418.jpg
  2. Press down lightly on the top of the ink cartridge latch of the ink cartridge to be replaced and then pull the lower section of the latch toward you to unlatch the ink cartridge.
  3. Grasping the sides of the ink cartridge, pull the cartridge toward you to remove it as shown in Figure 2. Figure 2: Removing the cartridge after raising the latch c00224419.jpg
  4. Remove the replacement cartridge from its packaging, and touching only the black plastic, gently remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tape c00224420.jpg
  5. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage as shown in Figure 4. The black ink cartridge (HP 56 or HP 27) goes on the right side (with the gray latch) and the tri-color cartridge (HP 57 or HP 28) goes on the left side (with the blue latch). If the optional photo cartridge (HP 58) is installed for six-ink photo printing, it is installed in place of the black ink cartridge. Figure 4: Inserting the cartridge c00224421.jpg
  6. Place your hand on the latch as shown in Figure 5, with the thumb pulling the end of the latch toward you. While holding the end of the latch out, press down on the top of the latch until it stops and then release the lower portion of the latch with your thumb so that it catches under the tabs. Do not force the latches into place or damage to the unit might occur. Close the all-in-one after latching the ink cartridges in place. Figure 5: Latching the ink cartridges in place c00224422.jpg
  7. Close the print cartridge access door.
  8. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press ENTER on the front panel to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press ENTER to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Storing the option photo printing cartridge while not in use The optional photo print cartridge (HP 58) that may be purchased separately for six-ink photo printing includes an ink cartridge protector. The protector is designed to keep the photo cartridge from drying out when it is not in use and for holding and protecting the black cartridge when the photo cartridge is in use.
  • To insert a cartridge into the protector, slide it into the protector at a slight angle until it snaps in place.
  • To remove a cartridge from the protector, push down and back on the top of the protector to release the cartridge and then slide the cartridge out of the protector.
Figure 6: Inserting and removing ink cartridges from the ink cartridge protector c00224423.jpg Fixing error messages that appear after changing a cartridge After inserting the cartridge, one of the following messages appears:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge indicated in the message and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth, slightly dampened (not wet) with clean water. Each contact is very small and shaped like a rounded square. Figure 7: Cleaning the cartridge contacts c00224424.jpg
  8. Inside the HP all-in-one product, clean the contacts in the print carriage (the cartridge holder) with a clean cotton swab slightly dampened with clean water. Allow them to dry for five minutes before reinserting the cartridge(s) and turning on the printer. Figure 8: Contacts to be cleaned c00224425.jpg
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, contact HP for assistance.
Oct 13, 2008 | HP Office Equipment & Supplies
I have been given a psc 1310, without an instruction manual and without any ink cartridges.The diagram inside the machine shows 5 different numbered cartridges which the machine uses, 27,28,56,57 and 58. I...
Hello.
HP 27 - Black Ink (approx 220 pages)
HP 28 - Color Ink (approx 190 pages)
HP 56 - Black Ink (approx 450 pages)
HP 57 - Color Ink (approx 400 pages)
HP 58 - Photo Ink Cartridge (approx 140 4x6 photo prints)
Hope that helps!
Jun 07, 2008 | HP Office Equipment & Supplies
Hp photosmart 7350
The 7550 takes three cartridges 56(black) 57(tri-color) and 58 (photo).
If you replace the 57 but the 58 is also empty and still in its slot - you get green tinted photos.
So, check to see if you have the 58 photo cartridge still installed, and if it is out of ink. If so - remove the 58 - the printer will then default to "reserve mode" and you'll get better color.
Dec 16, 2007 | HP PhotoSmart 7350 InkJet Printer
109 people viewed this question
k24674
jasbo
jasbo
