Question about Princeton Digital Computers & Internet
Just moved computer to new home have Princeton VL1716 monitor. Plugged back on and not getting power to monitor. The power supply green light on bright but when I plug it into the back of the monitor the light dims and I cannot power up monitor.
  • rcarlucci Feb 06, 2010
    Can I use a power supply from a laptop
    to make sure that is the problem?
    Yes thanks.
  • Princeton Di... Master
  • 13,433 Answers
Hi either the power is plugged to the display wrong, or then the power adapter can no longer provide the required voltage, the powersupply would either need repairs or to be replaced. The light dimming is the key sign of failure here. the powersupply is most likely unable to provide the required power the light dims out when its under too much load that it can't handle anymore. either take the powersupply to a electronics repairer or replace the powersupply.
Posted on Feb 06, 2010
  • Ekse Feb 06, 2010
    Only if the voltage rating and the polarity of the adapter are the same.
    if the voltage is higher than the original power supply, you will ruin the display. Very small voltage differences possibly 0.5 volt difference might not cause any problems.
    next the more important thing, you need to make sure that the polarity of the plug that goes into the display is the same on both power adapters.
    You will find this kind of small set of symbols in the label of the power adapter, both adapters must have the same polarity or you risk ruining the display in a way that will require further repairs or replacements inside the lcd monitor.
Monitor has no power to it. The power cable and V...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Princeton Digital LCD1711 17" LCD Monitor
Have loss of signal...have power...brief flicker of screen then total black...any idea of problem?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Princeton monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Princeton Digital VL1716 17" LCD Monitor
I have a 17 inch princeton monitor and the screen goes off frequently. each time it was every 15 mintuires now it goes off every 4 to 5 mintures. i turn if off and back on and it works. help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Princeton Digital VL1716 17" LCD Monitor
VL1716 Monitor screen black
they are using java and possibly dhtml scripts, your browser may not work properly with their site, but this is the link
http://www.sonyrewards.com/en/home/base/?ref=http%3A//www.sony.com/index.php
Aug 20, 2009 | Princeton Digital LCD17D (Graphite) 17 in....
Princeton Digital VL1716 monitor - no image and completely dark
1. Most of the time it's the florecent tube about to go out. Check other posts to replace it.
2. Alot is the adapter after a while will lose voltage check the voltage out of the adapter it should be 12V at 4A or 5A would work fine.
Jul 13, 2009 | Princeton Digital VL1716 17" LCD Monitor
Need cable and power supply
Power Adapter Input AC 100-240V, 50-60Hz, Output DC 12V/4.0A
This may help. Just make sure you have the right dc output mentioned on the back of your monitor (12v4a or 12v5a) if any lower your monitor will shut off after displaying for few seconds then electrical smell will come out from your ac/dc adapter. When it overheats it shuts off.
http://www.alibaba.com/product-gs/51210391/TFT_AC_Adapter_for_12v_4a.html
Manual
http://www.princetongraphics.com/site/download/manuals/vl1716.pdf
Jun 14, 2008 | Princeton Digital VL1716 17" LCD Monitor
Computers & Internet Logo
29 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
