Question about Acer Aspire 3000 Notebook
Whem turn on my PC, shows: windows can not find 'C:WINDOWSsistem32 ovageracaoKlbanker2009bykpdocvchost.exe' what it means ???
    Problem Solver:
  • 16 Answers
That means that you're missing a system file that allows your programs to communicate with your laptop properly. You need to look through your programs and find out which one most closely resembles what that says and attempt to reinstall that program. it would appear to be a banking program by the looks of it but don't take my word for that. Also, run a virus scan and make sure there's not something targeting your system 32 files. If there is a virus or malware then your problems will only grow more severe.
Posted on Feb 06, 2010
  • 4 Answers
It means one of you Win32 files has probably become corrupt, the easiest fix is reinstall windows with your restore disk
I need to download unlockhd.exe for 64bit windows 7
What is the .exe file for? I mean what are you trying to do
Feb 28, 2014 | Acer Aspire One PC Notebook
Tip
It didn't work in my Windows XP. When I try to delete logon.scr and rename...
How to Crack a Windows XP Administrator Password
(Before you continue Read the Updates at the bottom)
This is only for educational purpose it is a simple way to Hack the Window XP Administrator Password and also get away with it. To Hack the Window XP Administrator Password not many steps are involved especially if you already have a knowleged of working with the DOS prompt.Here are the steps involved to Hack the Window XP Administrator Password .
Go to Start –> Run –> Type in CMD
You will get a command prompt. Enter these commands the way it is given
cd\
cd\ windows\system32
mkdir temphack
copy logon.scr temphack\logon.scr
copy cmd.exe temphack\cmd.exe
del logon.scr
rename cmd.exe logon.scr
exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
A Brief explanation of what you are currently doing here isYour are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr. andSo basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this commandnet user passwordExample: If the admin user name is clazh and you want change the password to pass Then type in the following commandnet user clazh passThis will chang the admin password to pass.
Thats it you have sucessfully hacked the Window XP Administrator Password now you can Log in, using the hacked Window XP Administrator Password and do whatever you want to do.Here are the steps involved to De Hack or restore the Window XP Administrator Password to cover your tracks.
cd\
cd\ windows\system32\temphack
copy logon.scr C:\windows\system32\logon.scr
copy cmd.exe C:\windows\system32\cmd.exe
exit
Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click Yes to overwrite the modified files.
on Oct 03, 2009 | Microsoft Windows XP Professional With...
I downloaded prince of persia warrior within and want to play it, but when i clicked on princeofpersia warrior within.exe, it showed that it is not a valid win32 application.
Make sure ur using windows xp
and hardware minimum requirement
then also same problam it mean ur exe is currrept try to replace ur exe file
Sep 22, 2011 | Ubi Soft Prince of Persia: Warrior Within...
When I turn on my computer it shows that m3plugin.dll is missing what can I do?
That was a virus , luckily your antivirus has already removed it from your pc. the one trace left is in registry which will try to load it on startup.
Get rid of it:Start, Run, type regedit and press enter
Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe . if you can see some other after that like Explorer.exe C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then right click on it, Modify and delete the second file from the value, means it must remain only Explorer.exe
Next check for the key Userinit. the value must be C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that some thing is there , then delete it.
Ok that's all. restart your system .
Jun 14, 2010 | Compaq Presario 700 470024-192 Notebook
Whem i turn my computer on its says no operating system found.
Unfortunately that means either your windows installation is corrupt and needs to be reinstalled or the hard drive has failed and needs to be replaced. If you do not have a windows xp disc you will need a technician to do this as you will not be able to without the disc. If you do have a disc however follow these steps.
First insert the windows XP disc into the drive
Then when the machine says press any key to boot from CD press enter
Wait for the windows setup to load completely
Then highlight the windows XP partition it should be labeled windows XP
Then hit R on the keyboard
This will start a repair installation of windows
If it does not show the windows xp partition try installing to unpartitioned space
If the windows disc cannot find the hard drive or the repair does not completely unfortunately it means that the hard drive has failed and needs to be replaced.
Feb 26, 2010 | Compaq Presario 5000 PC Desktop
Uninstalled the camera but the "vm_sti.exe" is still eating my cpu
Your post ..."C:\WINDOWS\VM_STI.EXE...clean this from my pc..." would mean remove/delete.
Initially, pls try to:
  • Uninstall the Philips SPC 200NC;
  • Run in Safe mode and delete C:\WINDOWS\VM_STI.EXE;
  • goto Start, Run, type "msconfig", click on Startup, uncheck reference(s) to C:\WINDOWS\VM_STI.EXE;
  • open Windows Task Manager, Applications (or Processes), highlight VM_STI.EXE, click on End Process button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 12, 2008 | Philips SPC 200NC Webcam
Message displayed at startup of pc
This is a trojan that has been removed, but the startup file is still in the registry, click start, run, then type msconfig, on the start up tab in the next window look for explorasi.exe and untick it.
restert the pc, select don't show aghain when the window pops up and it shouldnt show any longer
Oct 19, 2007 | Computers & Internet
System file is "missing or corrupt"
You MUST use the installation bootup disk to install windows it is the only way........... NOT THE RECOVERY DISK this is a MUST. Allow it to go through the motion of installing Windows until it cannot go any further. Then press the "R" key for the console. When in the DOS screen TYPE ... chkdsk /p Windows will repair itself and then you will recover all your data it should be back to normal.
Sep 24, 2007 | Compaq Presario 700 470024-192 Notebook
Turn off problem
If you have (L)lsass.exe, that is a windows executable file, if you have Isass orisass.exe, then you have a trojan, run your antispyware and antivirus programme using safe mode (press F8 on boot up) to enter safe mode. Also you must turn off system restore before you run the virus removal, then turn it back on again.
Sep 12, 2007 | Microsoft Windows XP Professional With...
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
