Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The top burner on the left rear does not litght.
The top burner on the left rear does not litght. I have a ge model xl44 range. where can I get a new set of burners.
e-mail jnflenz@verizon.net
  • 572 Answers
It might be the ignitor itself. the spark
Posted on Feb 06, 2010
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
    If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
    Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
    Low Heat from GE XL44 gas range
    you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
    Dec 08, 2008 | GE Spectra JGBP35 Gas Kitchen Range
    GE XL44 pilot
    I dont know if you recieved an answer yet but this is a fairly easy fix. Open your oven door and remove your bottom oven plate. You now should see the burner element running down the middle. at the rear of the burner element is the ignite r (small porcelin bugger with two wires) remove this and replace with a new one GE #WB2X9154 available from the repairclinc.com website for 69.80 plus shipping. i just ordered (2) they seam to go out like clockwork every 2-3 years. To be safe unplug your ovens 110 volt cord first.
    Good Luck
    Jim
    Aug 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    XL44 Self Cleaning Gas Range
    your set up foir the wrong type of gas
    you probaly have a natural gas oven
    'and your using propane
    Dec 16, 2007 | GE JGBP24 Gas Kitchen Range
    Top works bottom doesn't
    I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
    Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
    Ge xl44 I think pilot not lit. no more snap - snap and does not light
    relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
    Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
    GE XL44 Gas Stove
    Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
    Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    161 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
