Question about Evesham E-Style C2.4 Pro (E-STYLEC2.4PROMAR04) PC Desktop
Computer started the desktop icons showed up then the computer fan stopped and green light went to orange and would not start up
  • joecoolvette
    joecoolvette May 11, 2010
    Make sure you always keep the inside of your computer clean, as well as the Power Supply. Computer Unplugged from power, open the computer case, use a can of compressed air for computers. Also use the plastic straw that comes with the can of air. If the dust 'bunnies' are extreme, plus the dust, you may have to additionally use several Q-tips to dislodge the thick junk, then follow with a can of air. TOUCH the metal frame of the computer case , BEFORE you reach inside to relieve your body of Static electricity. (Computer UNPLUGGED from power. Not shouting) From your brief diagnoses I think the inside of your computer is dirty, and the Power Supply is bad. Weak voltage power rail.
  • 102 Answers
Try reseating the fan power cord on the motherboard. If that doesn't work try replacing the fan.
If it still doesn't work then you PC has suffered some damage when the fan stopped working.
Posted on Feb 06, 2010
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the...
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Oct 20, 2013 | Intel Motherboard
Rocstor icon disappears from desktop and light is half orange/green
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
My Dell Optiplex 620 started rebooting itself every time Windows started up and then it just went dead. I push the 'ON' button on the front of the computer and nothing happens. I have no lights, no fan,...
I would suspect that the power supply has gone bad and has to be replaced. A simple task, really. var fctb_tool=null; function FCTB_Init_b10486e133b24d6ca38e4d39d69b43a1(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_ee2e8b71ff554752b93d52dd01ec84ba(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Dell OptiPlex GX620 PC Desktop
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
Computer does not start. Replaced motherboard and RAM. Hear the fan when I start the computer
The monitor has the problem. the message only means, the connector is not properly connected on motherboared . please try another monitor.
I am sure about this...monitor or the connector ( as u have changed the motherboard) of the monitor has the problem.
Apr 19, 2009 | Dell OptiPlex SX270 PC Desktop
My presario 6000 starts, but then it turns off after about 10 sec
do you know how 2 remove your memory? sometimes computers go crazy like this when you dont clean it regularly try 2 remove memory clean the slot with a brush as well as the memory. then put it back and see what happens. worth a try...
Jan 28, 2009 | Compaq Presario 5000 PC Desktop
Intermittently the power button constant orange fan full speed
Try removing the battery from the motherboard if its not soldered and leave it for an hour then out it back in, that might reset you bios and fix your problem.
Nov 25, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Evesham E-Style C2.4 Pro (E-STYLEC2.4PROMAR04) PC Desktop Logo
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
