Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
How do I secure my sbg900 from outside users - Arris SURFboard SBG900 Wireless Router (DHSBG900)
    President:
  • 949 Answers
You need to set security to the router, even if you use wep, it is better then an non secured.
Its hard to explain all the details, please read your manual as this will walk you through the process, wep is easy and the more security you have the more detailed.
You can also set your router to only see your mac address, your mac address is the address of the wireless lan that is in your laptop or computer, each one has a specific number, and it is usually a 12 digit
number.
Every router is different in the security it has and some only have wep, so it depends on your router what security you can set.
If you don't have the manual just go to the website of your MFG and download it.
If you have more questions or help after reading it please post back.
Posted on Feb 06, 2010
Changing security key on my modem surfboard wireless sbg6580
Use the default user name and password to login... then you can go to wireless tab and chamge the WPA key to whatever you want.
Sep 22, 2014 | Arris SURFboard SBG900 Wireless Router...
Wanting to secure wireless router
Here is a direct link to show you step by step how to secure your router,simply copy and paste address into address bar
http://www.ehow.com/how_6529194_set-security-motorola-sbg900-surfboard.html
Mar 24, 2011 | Arris SURFboard SBG900 Wireless Router...
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
How do i put a password on my wireless motorola router?
Use the Wireless > SECURITY — basic Page to encrypt your transmitted data. Choose one of:
If all of your wireless clients support WPA encryption, we recommend using WPA instead of WEP because WPA:
• Provides much stronger encryption and is more secure
• Provides authentication to ensure that authorized users only can log in to your WLAN
• Is much easier to configure
• Uses a standard algorithm on all compliant products to generate a key from a textual passphrase
• Will be incorporated into the new IEEE 802.11i wireless networking standard
For new wireless LANs, we recommend purchasing client adapters that support WPA, such as the Motorola
Wireless Notebook Adapter WN825G, Wireless PCI Adapter WPCI810G, and Wireless USB Adapter WU830G.
For more information about the benefits of WPA, see the Wi-Fi Protected Access Web page:
http://www.wifialliance.org/OpenSection/protected_access.asp.
Configure on the SBG900 Required On Each Wireless Client
If all of your wireless clients support Wi-Fi
Protected Access (WPA), we recommend
Configuring WPA on the SBG900
If you use a local pre-shared key (WPA-PSK) passphrase, you
must configure the identical passphrase to the SBG900 on each
wireless client. Home and small-office settings typically use a
local passphrase.
Configuring a RADIUS server requires specialized knowledge
that is beyond the scope of this guide. For more information,
contact your network administrator.
Otherwise, perform Configuring WEP on the
SBG900
You must configure the identical WEP key to the SBG900 on each
wireless client.
Feb 15, 2010 | Arris SURFboard SBG900 Wireless Router...
Sbg900 router, login problem
try to configure the browser settings, follow the steps below
1. Go to internet options and select the security tab
2. Highlight Internet and click customer level button
3. Scroll down to the very bottom, under user authentication select automatic logon with username and password
4.rest customer settings to medium
Jul 16, 2009 | Motorola Computers & Internet
WEP security setup on SBG900
If you set a WEP security connection, of course you will be kicked out of your connection. You have to re configure your laptop to gain access to your WiFi, inserting the new password you set the WEP with... Hope this helps
Jun 02, 2009 | Arris SURFboard SBG900 802.11g/b...
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
Motorola modem SBG900
you must define DNS and Gateway!!! Go on My Network Places, right click, again right click on your network, select properties, TCP/IP and in there enter needed IP addresses!!!
Jan 25, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
144 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
