Question about Hitachi Air Tools & Compressors
I have a Hitachi EC12 compressor. At 120 psi, the
I have a Hitachi EC12 compressor. At 120 psi, the motor shuts off, but it relieves pressure until the motor starts again. This short cycling causes the motor overload to trip after about 15 minutes. The pressure relief valve is not bleeding the system down.
  • terijan Feb 07, 2010
    It makes sense to me. I will check it out tomorrow.
    Thank you.
  • Hitachi Master
  • 43,501 Answers
There is a relief that allows the pressure to come off of the cylinder head to enable easier starting when it restarts. Sounds like that relief is doing what it should but the check valve between the compressor and tank is bad.
Somewhere in the line from the compressor to the tank there is a check valve and that is no holding. Probably has dirt under the seat.
Heatman101
Posted on Feb 06, 2010
I have a Hitachi compressor EC12. Motor runs okay & air pressure gets upto 125 psi, however, its not giving out any air on my output hose. what is wrong with this? I would appreciated if you could...
When the pressure reducer fails, it may leak around the adjuster or it may close as yours has. A temporary fix would be to remove the safety unloader or a tank pressure gauge and install a tee fitting replacing safey or gauge and install a quick fitting for air. You will only have tank pressure available however this is a temp fix untill you replace the pressure reducer. You do not have to replace with factory parts, there are generic parts available at Lowes or similar stores. For factory parts go to www.toolpartsdirect.com. Good luck with your repair and post again if you have other question.
Aug 05, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I have a compressor that will run but if it gets up to pressure the tank will bleed all the air out. I turn the compressor off around 90 psi and I can use it then I have to turn it on then off before 120...
If I understand correctly the safety valve, item #64 on the parts diagram, is opening at 120lbs and not shutting until the tank is drained. If that is the case you most likely have a bad safety valve, part #881-493 which is available from http://www.ereplacementparts.com. The non-return valve is basically a check valve that prohibits the flow of air from the tank back to the cylinder. I hope this helps!
May 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 won't refill air after initial startup
hi there,
of course comparative cost buying and repairing make a cost reduction.if your compressor run smooth but tripping,make sure where on the right path of diagnosing of your compressor,we can check if the motor or compressor is shutting off the unit.disconnect the belt from pulley of the motor to compressor,run the motor if still tripping w/o load its better if you have calmp ammeter test,to check the current rating,if it is tripping motor is deffective replace the bearing.f motor is fine sr till tripping check the compressor also the crankcase bearing,replace worn out bearing.have a nice day dont forget to fix my rate.thanks a lot.
May 03, 2010 | Hitachi EC12 Portable Electric 2hp Air...
2 hp 120 v motor on compressor. motor will not start under load
bleeder valve is bad or dirty drain air unplug machine pull the back up plate control plate and make it shinny with emmeory cloth then clen it and try again, if it still does the same thing your going to nedd to replace unloader valve.
Apr 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Compressor fills,drains off a little but won't
sounds like the pressure switch is fused shut, more than likely it needs to be replaced, most single stage pumps should shut off at 125 psi max.
Jan 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My hitachi EC12 compressor starts up and fills the two tanks. When I connect my hose, the pressure in one tank drops to zero, then goes back up to about 60 psi, then very slowly builds back up to max...
how do you know one tank drops to zero unless you have a pressure gauge on both tanks sounds unlikely unless you are looking at the gauge on the pressure regulator
Nov 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC 12 Air Compressor does not keep pressure
to repair this problem (a) the pressure switch is not working,(b) check valve or non return valve sticking(stripe down repair and refit)
Sep 28, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 Compressor- weird hum
The burst of air you hear as the compressor shuts off is the cylinder unloading so it will not have to restart against a high pressure load. If the unloader is electrical it would explain the hum that you hear. This could be a normal function.
Aug 24, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Air Tools & Compressors Logo
69 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
