Question about Cisco Computers & Internet
I have a linksys wrt300n wireless router and an Intel WiFi 4689(?)abgn wireless adapter. Can some one tell me why my connection speed fluctuated between 30 and 130mbps with excellent signal and how I can fix it? Please help.
    President:
  • 949 Answers
Do you this set to wap, What is the security that you are using,
if you did not set a security and it is open, anyone can be using your signal. wep can be hacked very easily.
Now, how do you know if is fluctuating, are you going by speed test
or by downloading, either way you will always get different speeds
depending on the website you are accessing, there is always speed changes to the internet depending on your ISP and the traffic that is
using it.
Posted on Feb 06, 2010
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
My wrt300n power light does not come on when trying to reinstall my wireless
If the power light on your router wont come on , there are 3 possible reason for that:
The power outlet where the router is connected can be bad so what you can do first is to connect the router on a different power outlet and check if same problem.
The power adapter of your router is bad , so if you can try a different power adapter that will be good.
The router itself is bad after you tried those steps and still wont power on , so if the router is still under warranty better have it replace of call Linksys support via this number 800-3267114.
Sep 09, 2010 | Linksys WRT300N Wireless Router
Skinner marvell yukon 88E8001 and Mototola sb6120 linksys wrt300n router each time i connect the router my speed go's from 1.0gz down to 100mbps the link light changes from blue to amber?
1 Check QOS ( Quality of Service) per network devices in the\in the "game" support tab of the router GUI ( Graphical User Interface). this will affect the speed if the bandwidth is not managed here with several device running,
Check with your provide if you still have a speed issue.
May 16, 2010 | Linksys WRT300N Wireless Router
My xbox can not connect to the router wrt300n
You will need a signal extender.Normaly the signal shoud be enough to make a good connection but that depends on the enviroment.
May 04, 2009 | Linksys WRT300N Wireless Router
Linksys Wireless N adapter Missing Hardware.ID
Hi Kathy,
Please do this first. go to control panel>add/remove programs, uninstall the Linksys Wireless N adapter.DO NOT UNPLUG THE WIRELESS ADAPTER FROM THE PC. Insert the Linksys wireless N adapter cd(DO NOT RUN THE SET UP). If the set up wizard shows up CLICK exit or cancel.Restart the pc with the disc in and the wireless adapter connected. When the pc boots up you will see the found new hardware wizard. Continue with the wizard, Select No not this time, Select install software automatically. If this is successful, your pc should be able to detect your wireless network
Mar 10, 2008 | Linksys WRT300N Wireless Router
Configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Aug 05, 2007 | Linksys WRT300N Wireless Router
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
102 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
