Question about Energizer Ultimate Lithium AA Batteries
Are energizer c2025 and c2032 lithium batteries interchangeable. What is the difference between them.
What batteries can i use instead of smashing batteries? Duracell ?
That camera takes lithium batteries. Duracell are DL123. Others are Energizer CR123 or Rayovac CR123A. The 123 is the key here. Other makers of lithium disposable batteries will use different letters, but the 123 is what you're looking for. They should still be available at Walmart etc. Panasonic CR 123APA 1B CR 123A Photo Lithium Battery Retail Pack Single
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
How many hours will 4 AA lithium batteries power a constant draw of 2.5 watts?
2.5 Watts sounds pretty high for an LED strip. If the batteries are paralled and the applied power is 1.5 Volts, then you will be pulling 1.6 amps - the batteries won't last long at all. The batteries are good for around 2500maH, (Milliamp hours). so figure you may get around 2 hours of life for the batteries.
Jan 14, 2013 | Audiovox Energizer Lithium Batteries 2...
I wonder what is the model of the battery using on HP 10b
HP 10b Calculator requires two CR2032 Lithium batteries. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For further information you may refe to HP 10b Manual
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 27, 2011 | HP 10b Calculator
What is the right battery to Minolta XG-1?
Hi
check the following
Energizer 3V Lithium Camera Battery - EVR2L76BP
Energizer Silver Oxide 1.5V Watch Battery - EVR357-303TS
Duracell 1/3 N-Cell Lithium Battery 1 Pack - DL1/3NBPK
Energizer Silver Oxide 1.5V Watch Battery 3-Pack - EVR357BP-3
Cheers
Tejodhar
Jan 04, 2010 | Konica Minolta Photography
Flat Batteries
I've turned many of my customers into users of the Energizer Ultimate Lithium AA batteries. Many people who have been ready to throw their camera away find the Energizers fix all their problems. Make sure to get the Energizer Ultimate Lithiums, as there are some lower output Energizers available too.
Aug 31, 2009 | Fuji FinePix S7000 Digital Camera
Taylor 7532
I just changed the batteries today in min and it was a Litm. battery C2032
Dec 29, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
I'm trying to find out if the new 19.2v C3 Cordless drills batteries are interchangable with the original 19.2v cordless battery. Also the new ion lithium batteries, Can the be used in old 19.2v drill?
I "m 99% sure Milwalkee is the only company that is interchangable..lithium ion and Ni cad ......... the new Milwalkee Lithiom ion chargers will chare both lithium and nicad, but the ni cad chargers will not charge lithium ion. Thanks Hope this is helpful!
Dec 10, 2008 | Drills
Batteries
firmware update is a update through a usb cable to update camera software internally from manuf website-try a set of energizer lithium batts in camera-not rechargable but i get over 500 pics on sngle set-some cameras won't register accurate bat levels or work well with recharables
Aug 20, 2008 | Vivitar ViviCam 8400 Digital Camera
Pentax optio 60
The best batteries in high-drain devices (like digital cameras) are the Energizer Lithium AA's. We sell tons of them to customers who re-purchase them again and again from us. As to why your Pentax is consuming them at such a high rate is a mystery. Try the Energizers, I fully believe you'll see a huge difference.
Jun 16, 2008 | Cameras
New camera at Christmas. Low Battery always on. Using Energizer Rechargable 2500mAh. Third set of batteries.
try energizer lithium batts- some cameras very very strange about batterys-have a sony that will only work w/ sony or energizer lithium-bought all other types and they do not work-i get 300-500 pics per set of lithiums-good luck
May 13, 2008 | Cameras
Energizer Ultimate Lithium AA Batteries  Logo
251 people viewed this question
Top Energizer Cell Phones Experts
William Alequin
Are you an Energizer Cell Phone Expert? Answer questions, earn points and help others
