Question about GE Profile JT955 Electric Double Oven
My GE Profile oven is beeping every minute. I've
My GE Profile double stack oven is beeping approximately every minute. I've cut the power to it and that did nothing.
  • 572 Answers
If its an f-7 error code its due to a stuck error code
Posted on Feb 07, 2010
On a GE Profile Performance oven the code F7 show up on the key pad and the oven Beeps. Hitting the end or stop button stops the beepimg for about 5 minutes. Turning the power off achieves the same...
Hello there
The code can be caused by a faulty keypad or a Stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel. :
furtrhermore
Jul 21, 2010 | GE Profile JTP56 Electric Double Oven
Built in double oven GE profile
F7 code is 'shorted matrix or start key' could be due to a problem with the key panel or control.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
Ge profile double overn
This is a common problem. I made this fix 2 years ago and it works like a charm.
http://www.fixya.com/howto/h155060-dreaded_f7_error
Jul 19, 2008 | GE Profile JTP56 Electric Double Oven
JTP56 Double Oven Beeping and Display FO Code
May 18, 2008 | GE Profile JTP56 Electric Double Oven
JTO56
It's a common problem posted all over the internet. This solution works if you're willing to try it. Make sure you cut off power at the circuit breaker box in the garage.
Apr 28, 2008 | GE Profile JTP56 Electric Double Oven
After self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
Dec 24, 2007 | GE Profile JKP56 Electric Double Oven
F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Nov 07, 2007 | GE JKP45 Electric Double Oven
GE Profile JT955 Electric Double Oven Logo
573 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
