Question about Krups Novo 2300 Espresso Machine
I have not used my krups novo 2300 plus for several years. When I attempted to restart, I had problems. I filled the container with water, turned on the on/off switch, waited for the lower light to go out, then moved the lever to the right. In the past, a few seconds later, coffee would be dispersed through the machine. Instead, when I move the lever to the right side, the pump sound occurs, but no water is pumped through the machine. I have noticed the "burner" is hot. I have removed the screws for the "burner" in an attempt to clean the parts in case there was a lime buildup or something like that. everything appears to be clean. Help!!!
  • gmanrtw Feb 08, 2010
    Thanks for the reply...I need to re-assembe the machine and try it....I have CLR in the house....should I use that first or will it be difficult to remove the smell / taste?
    marty
    Sergeant:
    Champion:
  • 258 Answers
More than likely with the time of no use the pump itself has is stuck in position. im sure that it sounds like its running but is really humming. now i now its not the easy to access pump but try running it and give it a couple of jolts thats worked on a few of them if not get back with me thanks josh.
Posted on Feb 08, 2010
  • jwtbagger Feb 08, 2010
    well i havent tried clr in mine but its bio digradable so it shouldnt be to hard to clean out.
    Guru:
  • 1,051 Answers
Empty as much of the water as possible and fill about half way with white vinegar. Let sit overnight. The vinegar will clear most buildups that may be causing an obstruction. After sitting overnight turn unit on and allow vinegar to run through. This should clear the machine. Once cleaned run clean water through machine 2 or 4 times to clean out the vinegar.
If this does not clean it buy a small bottle of CLR and use that in place of vinegar. CLR is a cleaner for Calcium Lime and Rust
Posted on Feb 06, 2010
  • Bob Korsu
    Bob Korsu Feb 09, 2010
    Go ahead and use the CLR. Just do a couple of extra rinseing afterward.
Xp 9000 stuck in descaling process
Do you hear the pump running? Is it possible that the pump has ceased to function?
Aug 25, 2014 | Krups Coffee Makers & Espresso Machines
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
I need a manual for the Krups FNC2 Novo 3000 Espresso Maker
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.scribd.com/doc/15940731/Krups-Novo-2300-3000-Manual
Oct 13, 2010 | Microwave Ovens
Krups Novo 2000 ~ water isn't flowing. I bought this used at a yard sale, and I must say it looks as tho it was hardly used at all. Today I plugged it in, turned the power switch to on until the temp...
If the pump is bone dry sometimes they refuse to pump. In the past I have found some soft tubing that will fit over the water inlet where the tank plugs in. I then fill the tube with water and pressurise it with my mouth while operating the pump. Often this is enough to prime the pump and start it pumping. The downside with a machine that old will probably be lack of new group head seals, you will probably find they are obsolete.
Apr 27, 2017 | Krups Espresso Novo 2000
Same Problem - no water goes through in either mode
remove screw in centre of group head and remove valve and spring, clean and reinstall.
Sep 21, 2009 | Krups Espresso Novo 2100
Need to fill resivoir how much
Unplug coffee pot, empty over sink, turn on to ensure it has pumped all water out, turn off, refill with water, restart normally.
Sep 05, 2009 | Krups FME2 Coffee Maker
There isn't enough pressure to pump water through the coffee
Chalk in the system, let it run a couple of times with plain vinegar. just fill the machine with about half a liter (one water container) vinegar and collect the vinegar in a cup so you can reuse it. run the full 0.5 liter, wait an hour and repeat. Than run 2 full watercontainers plain water. should work again. Cheaper than antichalk fluid and works the same
Mar 17, 2009 | Krups Small Appliances Espresso Machine
I need a 2-cup filter
GOOGLE "2 cup filter for Krups espresso Novo 2100"and your problem will be solved.
Jan 29, 2009 | Krups Espresso Novo 2100
Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Jan 19, 2008 | Krups Orchestro 889 Espresso Machine
Krups Novo 2300 Espresso Machine Logo
71 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
