Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Color gos in and out sometimes green color is gone and sometimes its greener
30000 litre pool keeps going greener and greener. the more chlorine I put in the more greener it goes
you also must have a working pump with good flow.check pH first then balance the rest of the chemicals,
Jan 11, 2017 | Pool & Spa
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
While palying, game stuck in & green light goes off immediately
if it gos off , please dont try swicth it on again, give some rest , unitil u sure the heat is gone or the ps3 is not covered with any kind of materials .
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Turned off with out doing anything
if it is a red light.... you have the ps3 equivalent to the rings of death on a xbox 360 meaning it had a serious system crash it has something to do with the gpu and cpu and you must send it back for a replacement as it is unfixable, here what the colors mean, red=dead, green=good, yellow=overheated
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
LCD screen shows green shadows typically behind the cursor and eg on each alternate line when in windiws explorer page. It looks a bit like the old printer paper that had alternate white and green lines. ...
look for driver clashes or new drivers with this:
http://www.drivermax.com/
if there is none the i would say there is a loose connection in your monitor. I wouldnt reccomend taking it apart yourself however it fairly simple to fix and shouldnt cost to much to fix.
thanks
CBZ
Apr 26, 2009 | Dell Latitude D505 Notebook
Sometimes has green tint.
YOU ARE 100% CORRECT it is the cameras ....... as a tv camera wears out green is the last to get weak . so the picture turns green crt tvs do the same thing
Mar 25, 2009 | Sony Televison & Video
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
14 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
