Question about Bosch Classixx WVF 240S Front Load Washer / Dryer
Mould build up on the grey door seal. tried bleech and other strong products - want to replace seal if possible. What to do or use?
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch Classixx WVF 240S front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Posted on Jul 23, 2013
  • 56 Answers
The mold is caused from too much soap. a front load uses such a small amount of water only 2 tablespoons of soap is needed. replace the boot and cut down on the soap
Posted on Feb 07, 2010
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
My maytag neptune washer has black residue on the seal. I have tried everything & nothing seems to take it off. I am now concerned that it is mold. Has anyone experienced this same problem?
Hi just read your posting.The black residue is most likely mould.I have seen it on a few front loaders.Have you tried the product called Mould off ?It helps on some machines.Worse case you might have to replace the door seal.Please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Maytag Neptune MAH6500A Front Load Washer
A build up of brown slimy mould which marks clothes after washing. The door seal is stained brown in places and the brown slime is building up in the folds of the doo seal. What can I do?
try manualy cleaning the door seal with bleach and then amonia, ( NOT TOGETHER, ONE AT A TIME )
then pour some amonia into the machine and run it. amonia and/or vinegar work great to clean washing machines. but please note : this should be done seldomly as Amonia is a corrosive towards electrical parts.... hope this helps.
Oct 18, 2009 | Washing Machines
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
Hello, our miele w5040 is about 6 years old and we
if you mostly use lower temperature washes a bacterial mould builds up inside the machine. it can be seen as a black residue in the soap dispenser drawer and in the folds of the rubber door seal. a grey sludge also builds up on the inside of the wash drum and the drain filter. doing at least one hot wash ( above 60 C ) a week can stop this happening.
Aug 26, 2009 | Washing Machines
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
Black mould round door seal
There are several reasons for this to happen.
the primary one is the fact that you are doing a lot of low temp washes, and this causes a build up of grease and dirt around the door seal, the mould you refer to is actually bacteria.
You must do a high temp wash at least once every 6 to 8 weeks, put powder and or detergent in as usual, but no washing, and let it do a full cycle.
This is called a maintenance wash and helps prevent what has happened to your m/c.
Thoroughly clean the door seal with a scouring pad or stainless steel wool, you will not harm the seal,
You will probably find the seal will be stained, but as long as you get all the mould etc off, it will be o/k.
Plz rate my solution.
Thanks
Dec 29, 2008 | Indesit Washing Machines
Washing machine does not wash clothes
You are possibly washing at the wrong temp, or not using sufficient powder or detergent.
The m/c is not rinsing properly, check that it is pumping o/k.
If there is a build up off slime and mould on your door seal, then you are definately washing at too low temp.
At least every 4 to 6 weeks, do a high temp wash with powder in but no clothes.
This is called a maintenance wash and helps to keep the inside parts clean..
If your door seal is stained, clean as best you can with a scourer pad or similar. You will not hurt the seal.
plz rate my solution .
Thanks.
Dec 17, 2008 | Washing Machines
Mouldy rubber seal
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Regarding the mould; keep your door open after yur washing is done, (means dont shut it tight) it will help to dry the insides & prevent moulding. Only see your cat is not inside before starting a new wash.
And pl rate me if helped.................
Jan 24, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Classixx WVF 240S Front Load Washer / Dryer Logo
154 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
