Question about Garden
My gas blower wont start,,tried new gas ,,tried
My gas blower wont start,,tried new gas ,,tried new plug,tried cleaning filter
  • 25 Answers
This is a common problem with blowers. trimmers, chain saws etc. I believe your carburetor needs to be rebuilt. The carb has very thin rubber diaphragms that meter in fuel to combustion chamber. If the diaphragms get hard (from sitting long periods with fuel in carb or from extreme heat) they won't flex enough to allow enough fuel in, If you need parts or more assistance email desertairrepair@aol.com.
Posted on Feb 12, 2010
Won't start
Are you getting spark on plug? Check to make sure wire is connected to plug, if still not starting. Is fuel getting to plug? Remove plug an see if its wet. If its wet it could be flooded. If not fuel lines are common on saws, tank in is a major problem it cracks an need replacing. Have you checked the on off switch? If it still wont start, carb is more than likely the problem. Remove it an get a rebuilt kit, they are cheap, carefully remove all parts clean out all orifices even small ones with a piece of brass or steel bristle from a brush, use carb cleaner to clean the parts, carefully put it all back together an it should start. That is about all there is.
Mar 25, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
Shindaiwa leaf blower EB8520 loose power every 5 secondes for 5 secondes
Sounds like you are running it with the choke on - is it spitting black smoke?
Jan 12, 2013 | Garden
Blower not running at high rpm when full throttle. Cleaned air filter, gas vent, gas filter and spark plug. Blower is 3 years old. Have not bought any new replacement parts.
Try removing the muffler and look inside of the exaust port, you should be able to see the piston in the full opening of the port. If you can, try starting and running at wide open throttle. If it runs fine( a bit loud, so wear hering protection), then you have a plugged or partialy blocked muffler or spark arestor. Sometimes rich mixture can cause excessive carbon build up.
Hope this was helpfull.
Nov 07, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Put new spark plug in new gas clean filter followed starting directions want start
The fuel system may need tending to. It may need new fuel lines, a cleaned fuel filter and the carburetor cleaned and adjusted. If this is an older unit, (even a couple years old) it may require some new internal carburetor parts as well. I don't like being the bearer of bad news, but this isn't always an easy fix. Your specific problem has to be diagnosed and by process of elimination, the problem resolved.
Oct 05, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Sears Gas powered blower 25cc/1.5 Cu. in 2 cycle 200 MPH/400 CFM Where's the fuel filter, so I can clean it?
I have craftsman 25cc 2-cycle blower-It wont turn over-I put new spark plug and cleaned filter. It dosen"t seem to be getting any gas. How would I know if its the gas filter and how do I put new one on? thanks,mh
Jan 23, 2010 | Craftsman 4 Cycle Blower/Vac
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
Wont start
try some starting fluid in the intake, clean the spark plug. is it an old blower?
Mar 20, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
