Question about Dell Inspiron 1525 Notebook
Reseated hard drive on my dell inspiron 1440 but same message app
Done this and nothing helped
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Perhaps the hard drive is not the only thing not communicating?
  • Bruce Volkers
    This is your first post on the subject. Would you care to post a little more information? Perhaps what error(s) you are seeing?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 113 Answers
Repalce hard drive
Posted on Feb 24, 2010
Cannot reseat my hdd not found?
Hi Robert Clark,
You may try reseating the hard drive by referring the below link which is a user manual for Dell Inspiron 1750:
http://downloads.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1750_service%20manual_en-us.pdf
However, if this doesn't help then please explain the issue with the hard drive then I can check and see what can be done.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Apr 08, 2015 | Dell Inspiron 1750 Laptop
My dell inspiron 1440 will only say bootmrg is missins
this could be a software fault requiring repair of windows oerating system using the windows installation cd or it could be a more serious problem of a broken hard drive which will need a new one.
before this check the boot order of your system by preesing f8 or f12 or entering setup and looking in the bios at the boot order. if it is wrong set to boot from hard drive.
Oct 13, 2014 | Dell Inspiron Laptop 1440
Dell inspiron 1440 error 2000-0146
Hi Gail
This error very much relates to your hard drive either having failed or is in the process of failing. The error may come up when the drive fails the S.M.A.R.T. Test (sounds stupid I know).
This test could indicate that the drive is not spinning up in the required time frames or that it draws more power or has needle placement issues.
Sadly here drive age may not have to say much. As a rule in computer electronics you can triple or quadruple every components age. So if the device is 3 years old in technology years it could be 9 years old.
Especially in mobile computing mechanical drives can fail faster even though manufacturers put in newer software to combat the issue of hard drive failure due to movement. For example a hard drive in simple terms is very much like an LP Player where a needle is running on the disc reading the data/music for playback. Now imagine what happens when your walking, moving (bus/train/car you name it) and this needle is exposed to various forces it normally wouldn't be exposed to. Basically that additional strain can cause these mobile hard drives to fail a lot faster.
In this case it does sound like you will need to look at replacing your drive and I would recommend doing this before it fails completely as recovering any data once this happens (photos, documents, etc.) will be very costly.
I hope this helps
Philipp
Apr 17, 2014 | Dell Inspiron Laptop 1440
Error code 2000-0142 hard drive 1 self test unsucessful status 79
It appears that your laptop's system board cannot not communicate with your hard disk drive. Either your hard drive is defective or the system board. Usually it's the hard drive.
Feb 07, 2011 | Dell Inspiron 1525 Notebook
I have a two-year old Dell Inspiron 1525 laptop. for no apparent reason, it will now not boot up. When I turn it on, I get the following message......"Internal hard disk not found. To resolve this...
The hard drive may have failed or a virus has corrupted the Cmos data.
Try entering the BIOS and checking that the Cmos recognises that the hard drive is there. If it doesn't, remove the hard drive and re fit it, booting up again.
Dec 27, 2010 | Dell Inspiron 1525 Notebook
My dell vastro laptop when i start no hard drive found pl reseated then i reseated again same message repeated
your hard drive has failed and is not being recognized, it is possibe to try a format and re installation of operating system but all data will be lost
Dec 14, 2010 | Dell Inspiron 530s Desktop Computer
My laptop is saying that it cant find the internal disk hard drive and that i would have to reseat it?i have a Dell Inspiron 1521..where do I find the internal hard disk drive on my laptop?
Internal disk drive..will be drive c:\...make sure nothing is loose on your laptop. if not. Go to control panel. Click ADD HARDWARE....and see if everything is enabled
Jan 31, 2010 | Dell Inspiron 1521 Laptop
Reseat the hard drive
shut down the laptop.
then, disconnect the laptop power, and battery.
remove the harddrive, then connect the harddrive firmly back into place.
reconnect power/battery and boot.
Mar 25, 2009 | Dell Computers & Internet
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron 1525 Notebook Logo
1,102 people viewed this question
Alun Cox
