Question about Kenmore Washing Machines
I have a Kenmore double action front loader washer model# 41742142100. after the first bit of water inters the machine won't tumble or spin. What might be the problem?
  • jmcrandell Feb 06, 2010
    IT IS NOT AN AFFINITY WASHER. THE BELT ON, THE DETERGENT DOOR IS CLOSED, USING HE DETERGENT, DOOR LOCK LATCH IS CLEAN. MY HUSBAND IS RATHER GOOD WITH MACHANICS BUT IF WE HAVE THE MACHINE OUT WITH THE TOP OFF IT SEEMS TO DO FINE BUT AFTER IT IS PUT BACK TOGETHER AND PUSHED BACK IT TENDS TO STOP WORKING AFTER A FEW LOADS.
  • Kenmore Master
  • 8,220 Answers
Well now it could be inlet valve screens are clogged, hoses backwards wrong detergent, detergent drawer open,detergent in wrong compartment. Corroded door lock assembly, filter clog, suds detect, slow drain. Belt off pulley, main drive pully warped. I have a manual I was looking at the parts of your washer and am guessing it is an Affinity washer made by electrolux for Sears. You might want to take a gander at this manual, I will leave it posted so you can print it,let me know if it matces your washer.
I have the manual HERE
Posted on Feb 06, 2010
  • 1 more comment
  • Dan Webster
    Dan Webster Feb 07, 2010
    OK good news I have the exact washing machine technical repair manual in my stuff.
    I have a Tumble action washer with AC motor repair manual: HERE
  • Dan Webster
    Dan Webster Mar 07, 2010
    Must be a bad flow meter. The flow meter gives the CCU intel on how much water is entering.
    You getting any fault codes?
  • Dan Webster
    look for water on the floor, the flood switchtch could be telling the brain their is water present. remove the bottom flap by tipping the machine back and removing the screws.
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Continues to thumping sound only on the spin cycle on my tumble action washer (front loader).
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 15, 2011 | Kenmore Kitchen Ranges
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore front loader washer
you need to replace the speed control unit (board) in the lower right corner in the back of the washer it is faulty
Jan 24, 2008 | Kenmore 44102 Front Load Washer
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
