I have a spirit soundcraft powerstation 600 powered
I have a spirit sound craft power station 600 powered mixing desk and two of the volume sliders are tracking out bleed-over each other i was wondering how easy they are to fit and what tools would i need to fix this problem thank-you m a cook
  • CHRIS TAYLOR May 11, 2010
    do you mean the master l & r sliders are difficult to effect control
3 Suggested Answers
  • 88 Answers
SOURCE: re spirit powerstation 600 when i lower the volume
replace or clean slider
Posted on Feb 08, 2010
  • 4234 Answers
SOURCE: How do I connect a
If you look in the manual at the "hookups" page 1, connect the controller as if it was an EQ. This will insert the controller between the mixer and the amplifier.
Dan
Posted on Aug 31, 2010
Gigrac 600 turns off, displays the Amp 2 clip light then turns off. All volume knobs are turned down. All external items are disconnected and it still turns off. My only complaint about these units is...
There is a bad amp in that divice that is causing an overload. The device then shuts down. This is not something that you can fix yourself. IT requires special diagnostic tools and troubleshooting as well as soldering ability.
Aug 17, 2013 | Soundcraft Gigrac 600 Powered Mixer
Sound craft lecternette portable lectern L46 volume not reliable
Probably the volume control is flakey, There will probably be a slot in the control body, spray some contact cleaner or WD 40 into the slot and work the volume back and forth. If there are any other controls do them also.That should take care of the problem. Getting to the control is your problem I am not familiar with that model.
Sep 12, 2017 | Soundcraft Music
The power supply blew and I need the schematic for the power supply.
Soundcraft USA
8500 Balboa Boulevard
Northridge
CA 91329
TEL: 818.920.3212
FAX: 818.920.3208
EMAIL: soundcraft-usa@harman.com
WEB: http://www.soundcraft.com
Sound Technology plc
Letchworth Point
Letchworth
SG6 1ND
TEL: 01462 480000
EMAIL: info@soundtech.co.uk
WEB: http://www.soundtech.co.uk
Mr Jorg ter Veer
Audio Pro Elektroakustik GmbH
Pfaffenstrasse 25
74078 Heilbronn
TEL: +49 (7131) 2636 400
FAX: +49 (7131) 2636 430
EMAIL: info@audiopro.de
WEB: http://www.audiopro.de
Soundcraft Homepage
Nov 04, 2011 | Soundcraft Epm6 6-channel Multi-format...
Hi Have a Souncraft FX16 and about 3 hours in after sound checks but before a show , the system gave off a pop and then a buzz.. Not good with a few 1000 watts out front. All channel PFL lights came on...
No experience other than decades of electrical engineering experience. Verify that your amps AND this mixer all are powered from the SAME receptacle or power conditioning module. This means running your power back to the mixer and ANY other connected equipment alongside your snake. Powering equipment from building receptacles at opposite ends of a room subjects your equipment to noise ground bounce that CAN trip the electronic fuses in equipment or cause some devices to lock up. All pro's in sound carry an extension to bring power to the mixer from where their amps get the power.
If your equipment gets too hot, try a fan on it. Moving air doubles the power handling capabilty. If powering unit down and right back on takes another 5 to 10 minutes, it is NOT a thermal issue. It would fail again in a minute. Regulators often run hot... they should have thermal grease or the silicone transipad thermal pads... they are grey in color.
Jun 01, 2011 | Soundcraft SPIRIT RM FX 16 II
Soundcraft GIGRAC 600 pre-amp power supply keep blowing the low valve resistor 1ohm. they are the resistor just before the bridge rectifier, for the low voltage feed. Once resistors replaced the unit...
The resistor is acting as a fuse and will continue to blow until you fix the REAL problem. LIKELY the filter capacitor(s) beyond the bridge rectifier are failing. One needs to use test equipment to measure the current through the resistor and see if it is reasonable. The capacitors can heal briefly and then start to short. One should also check the rectifier in operation with an oscilloscope as one diode could intermittently short.
May 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
Please help. Cannot turn the soundcraft gigrac 600 on.
Check the fuse. If it has blown, do NOT replace it without taking for service first. Additional damage often occurs when users replace fuses that have blown due to internal failures in equipment.
Also check that the power cord is fully seated... sometimes they don't quite make it...
Feb 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
We understand that your problem is: I have two jbl eon 15 two way (non powered) speakers. recently heard a loud crack through them (mic was not on)and since then my music and my voice now sounds really...
Likely a bass pin or tweeter has gone. Drop all on eq and then just turn bass/low up. Try each speaker separate. Then both together. They should sound exactly the same. Then repeat for high end. You'll find the suspect this way.
Mar 05, 2017 | JBL EON-1500 Main / Stereo Speaker
6 mnths old Alto L8 Mixing desk developed hiss on channel 1 only.
The slider or the amps for channel 1 may have a problem.
Sliders do wear out.
Try shorting channel 1 input and see if that affects the noise. A hissing noise is probably a bad preamp chip. That is shop work at a repair facility.
Aug 16, 2009 | Music
525 people viewed this question
 Grubhead
Grubhead
