Question about Sony KDF-E42A10 42 in. LCD Television
Color in center of screen is dull. We just replaced the lamp, didn't fix the problem. 6" on right and left edges look fine. Any suggestions??
  • 458 Answers
Need replaced OPTICS UNIT
Manufacturer Sony Part Number A-1123-071-A Description OPTICS UNIT BLOCK
Posted on Feb 06, 2010
My magnavox 51mp392h rear projection tv has a yellowish color on both the left and right side otherwise the picture looks fine. recently replaced the convergence chips, which fixed that problem
Its the CRT fluid.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 17, 2010 | Philips Magnavox 51MP392H Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Color
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My picture is dark and have changed the brightness
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Mitsubishi WD-62525 Red Status Light After Cap Replacement
maybe this help you, let me know. good luck
ok here new tips on v26 chaiss cust install new oem lamp with led lamp just blink only many time install new balister still shut down no audio no hv at all come with code 34 for test turn out to be that in power supply ther caps that wher blow up 3300 mf at 16v two them c9a38 ad c9a36 both same also note c9a62 1000mf at 16v thru c9a52 ad c9a82 ad c9a61 all 1000mf at 16v install 63v at 1000mf all same with both 3300mf at 25v fix the set now turn on with great pix cust old lamp too dark for pic install new lamp pic better ad reset lamp timer all good cust happy that cust got from mist the power supply board from looking from back of the set on left hand side all way in front u hav pull whole dmb bd to get to it want lets yu guys know[john leyva american video service center ] the right model number is this WD52525 HIT BAD KEY THIS RIGHT MODEL NO WD52525
Sep 09, 2008 | Televison & Video
Colour misalignment and focus
If you feel dull image and any yellow color problem you can change the lamp other wise no need to change the lamp.
There will be patten settings are there. so please inform service center service engineer will do this job.
Regards,
Prakasam
Feb 17, 2008 | Office Equipment & Supplies
MT830 Color Convergence (Blue Left - Yellow Right)
take a look here: http://www.extremetech.com/article2/0,1697,1049289,00.asp "... The others, however, have lost portions or all of their blue channels. TI's theory is that the shorter wavelength and higher energy of the blue light apparently causes the organic polarizing material in the LCD to get lightburn much faster. TI showed us a damaged LCD panel that controlled blue light transmission, and there was a large spot in the center that was apparently burned out..."
Aug 25, 2006 | NEC MultiSync MT830 Multimedia Projector
Sony KDF-E42A10 42 in. LCD Television Logo
105 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
