Question about Intertherm P3RA-048K Air Conditioner
My intertherm outside unit is clicking and I can hear a buzzer every so often. When the buzzer goes off the inside lights dim for a second. Model T5BD-048K and serial # T5A060500118. Product p3ra-048k is incorrect, the above model and serial number is correct.
  • 1,250 Answers
Sounds like the compressor is trying to start but is not. The lights are dimming as the unit is overamping. The buzzing noise is the motor trying to start and failing. The click is the unit going out on it 's safety device, unually an internal overload.
Hope this helps.
Posted on Feb 06, 2010
Got Intertherm Model # MGH-055AB.. It lights for ap 10 seconds goes out then goes out... Over and over again does not stay lit long enough for the blower to start running?? ANY IDEAS HOW TO FIX IT ?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If the s3 comes on then you have an issue with the unit and i would get a professional to help.
Air Conditioning Boca Raton
Apr 10, 2015 | Intertherm Heating & Cooling
Why is my Intertherm P681S unit getting hot and the fan is is stopping?
Is the outside running? Is the outside fan running? Probably what is happening the fan outside quits running and the compressor gets hot and goes into thermal overload. need to check to make sure the outside fan is running.
Aug 30, 2014 | Heating & Cooling
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
Heater goes on for about 30second and goes off and the lights goes on services heater
Heater is probably not coming on. What you hear running for about 30 seconds is the blower. After they blower comes on you should hear a obvious click. That is the igniter coming on. If you don't hear the click you have an electrical problem. If you do hear the click then either the heater is not getting gas - check the valves inside and outside the heater - or the flame sensor is not working correctly.
Good Luck
Apr 16, 2011 | Pentair MasterTemp 400000 BTU Pool and Spa...
Intertherm Furnace keeps shutting off as soon as it comes on. Model # G5RK072C-12
if its a fossil fuel unit meaning nat gas or propane and it lights then goes out in a few seconds try cleaning the flame sensor take out sensor then rub it gently with steel wool then replace should solve problem
Jan 24, 2011 | Intertherm Heating & Cooling
Thermostat wiring diagram for heat and cool unit
out door unit staying on disconnect the yellow wire for compressor if still on contactor bad points whare main line voltage is connected if unit goes off stat bad also check for weedeater damage to stat line at unit hope this helps most systems green fan yellow compressor blue common orange reversing valve white aux heat strip remove stat cover to see how unit is wired up
Jul 03, 2009 | Heating & Cooling
WONT COOL OUTSIDE UNIT DOES NOT COME ON FAN BLOWS INSIDE
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
Suddenly stopped cooling
Sounds to me like the run capacitor is bad. It is a dual one which means runs the fan and the compressor. No big deal capacitors are only 10 bucks and easy to replace.
First turn off the electricity to unit at breaker would be best. Next after you open the access panel locate the capacitor and make a note which wires go where one side is marked fan the other is herm. in the middle is comm. Take the old one in and get a new one same size and reinstall. Now parts only have one year warranty but they should have a discount on a person that bought a unit from them if you talk to them and tell them how can this happen only 2 years old. you know the story they might just throw one in for free to keep good business practice. Let me know how it goes. ken
Apr 16, 2009 | Intertherm P3RA-060K Air Conditioner
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
148 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
