Question about LG RC797T
Won't record HDTV. Is there a new recorder I can buy that will record HDTV. I just want to record. It doesn't have to come back in HD.
  • LG Master
  • 5,113 Answers
A Blue-Ray recorded will do that, just take your pick, but they ain't cheap!!
Posted on Feb 07, 2010
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
How to watch freeview hd on Panasonic tx-l37e30b
John, do you have an HD cable box? If not, you will not be able to watch anything in HD....call your cable provider if you don't have it.
TeeVeeMan2@gmail.com
Oct 23, 2011 | Televison & Video
I recently purchased an LG RH397D dvd recorder> Ihave now discovered taht it will not receive the new free view channels and I need a HD set top box. How to I connect the set top box to the dvd...
Hi, The set top box will more than likely have two coaxial connectors ( threaded/ribbed pieces of metal ) coming out of the back. also three R.C.A. connectors-these will be smooth and be colored yellow red and white. one of the coax connectors will say " IN FROM ANT> or CABLE IN) the other ( OUT TO T.V. ) hook up your dvd recorders " ANTENNA " input to the set top box's ANTENNA output. If your D.V.D. recorder doesn't have an antenna input then hook up the recorders audio/video input to the set top box's audio/video output. then you should be good to go. If you buy a H.D.T.V. tuner to receive FREE H.D. programming it may be possible to hook up to recorder with H.D.M.I. cables.( those connections resemble slots ) I hope this has been of some assistance, good luck, Prodzilla.
Apr 02, 2011 | LG Televison & Video
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
My Pioneer DVR-320-S tuner did not pick up the free-to air HD channels I can receive on my new HDTV. I am running the aerial through the DVD recorder to the TV. Can I run the aerial line into the TV and...
You might need a splitter (about 3 bucks at walmart) attach the Antenna to the side of the splitter with only one connection. Connect an RF cable to each of the remaining 2 connections. Run one wire to the DVR and the other to the TV. You can then watch one channel, and record on the other at the same time. You might not be able to record in HD if the recorder is not an HD recorder. Regular DVD recorders only record up to 500 lines, HD is rated at 720 or 1080 lines
Jun 02, 2017 | Pioneer DVR-320S DVD Recorder
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
E2 Front
I needed help with an error message E2 (Front) on my Magnivox DVD Recorder MSR90D06 not a 30" TV. I will try to locate the manual and replace the wires on the back of the DVD to see if I can get it to work. Thanks anyway.
Dec 26, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC) http://www.videsignline.com/howto/207400325
Nov 23, 2008 | Televison & Video
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
LG RC797T Logo
Computer Repairing
Computer Repairing
