Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My 5701 was working fine until it starting going off approximately 45 minuites after it is armed. When I disarm it the car and the remote chirp three times and unlock(green) and function(red)LED's go off once.
Same issue , have you resolved it yet? **** me off like no 2morrow
Posted on Feb 28, 2010
Car does not arm or disarm when door opened alarm goes off
Hi, I love the viper. Mine worked flawlessly for many years until one time my unit would not arm or disarm. Obviously 1st I checked batteries which were good. I took mine to installer and they said I had a remote go bad. He got me new remote and that was it. Sometimes I wonder if somehow I managed to hit a factory reset sequence on my remote. Considering your also having an issue with door contacts as well, I would hope it's not the main unit. My system also had a special override switch in the footwell, if you have one, perhaps you may have switched accidentally. Hope this helps in troubleshooting.
Dec 18, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5701 alarm is having issues.
First thing is to trip the system to see if the siren works then. If it does, then perhaps you inadvertently set the chirp commands to silent. If the siren doesn't work when the system is tripped then that's your problem. You'll need to find the siren and troubleshoot possible causes. I'd start with the wiring but the siren could have simply gone bad. You should be able to test it easily with a test light or multi-meter.
Mar 19, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When I try and arm my viper system it tells me it armed and then the arm and function LEDs flash. Help
That's what its supposed to do on the 2way remote. You would have recieved a 2 way and a 1way remote. The 2 way will chirp when it recieves a signal, whereas the 1way will not.
On the back of both remotes it will notate 2way or 1way.
cheers!!
Sep 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hi. I have a Viper 5701 alarm in my car. Arm and disarm goes very well with the control unit. But I cannot programming to pasive arming, always have to use de button in remote control to works. Is ther a...
Open door, turn ignition on then off. Press aand hold programming button until you hear one chirp. After you hear the chirp, release programming button, press and release button one then press and hold. You will hear one chirp. While holding the programming button, press lock button on remote to change option. One chirp is active arming(what you currently have), Two chirps is passive arming without locks, Three chirps is passive arming with locks. Turn ignition on to exit programming. Test system.
Jun 13, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My 2 way remote and car are both silent when ever i lock or unlock them and it gives me an error sound when ever i lock or unlock it how do I fix this
Hi, try and see if the user has been switched from car 1 to car 2 press and hold f for 3 seconds or until the remote beeps and the lock and or unlock leds turn on. car 1 will be 1 beep and armed led on. car 2 will be 2 beeps and arm and disarm leds on. if you press the f button while the leds are still lit then you can change to car 1 or car 2. good luck.
Jan 10, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When i arm and dis arm system i get error beep?
Hit f and then unlock
You may have lock out the remotes. If that doesn't work DEI has a one yr gurantee on remotes. In your box there should be a registration card. Call them.
Jan 26, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I bought the car with wiper alarm system and remote start. it wont start the vehicle, could it be because of low battery, the alarm its self works fine, arm and disarm
it may need to be programmed.......
-press the "f" button and hols for 12 seconds (ignore the beep at like 4 seconds.)
-press and hold the unlock button for 2 seconds...the remote should beep two times. each feature that is active will have an led light beside it. press the button to activate the feature. if the light is on the feature is on...
hope it helps...
Jan 06, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
VIPER 5701 GOES OFF ON ITS OWN
this is a EASY FIX.... if the car has a factory alarm installed, then the installer never connected the OEM disarm wire. its a LIGHT GREEN/BLACK wire connected to the H2 harness. just have them connect that and youre problem will go away .
JOSEPH GARCIA BEST BUY CERT M.E.C.P INSTALLER
Mar 24, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When i arm the car how can i hear the sound viper on
whats the make and model fo the alarm? and go to viper.com/support for more information
Feb 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
273 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
