Question about Jandy AQUALINK RS TELELINK KIT
JANDY AquaLink RS6. I can't get theHot tub/pool to stop running.
On my Jandy, Aqualink RS6, I can't seem to get the hot tub/pool pump to stop running. If you shut the pump off it will stay off for a while and then pop back on again and again. From some research it looks like it might be a relay. I took the outdoor front panel off and observed the black tab on the bottom of the Pool Pump Relay. When the pump is on under "Automatic Mode" and the pool is running the black tab is "IN". When turning the outside buttoms to the "Service Mode" the black tab goes "OUT". Is this a sign of a bad relay?
Could the problem be a "Hot Tub Relay" vs. the "Pool Pump Relay"?
If so, where is the best place to get a replacement relay? What should they cost?
If not a relay, what else could it be?
Much Thanks.
  • 2,926 Answers
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit boardJANDY AquaLink RS6. I can't get theHot tub/pool to - 2_bing.gif.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
The problem was a sticky reset button (recessed) on the outdoor control panel. The reset switch itself was fine. In any case, I lightly lubed the recessed button, which now moves fine
Posted on Feb 20, 2010
Jandy Aqualinks not turning on my waterfall or fountain in the pool and 3 out of 4 of my hot tub jets. How do I re-set or repair
Turning off the power and then back on will do a simple reset. Resetting your jandy will probably not fix your issue. The issue seems more like a bad relay or bad pump or the breaker for the pump may be tripped.
Jun 18, 2017 | Jandy Pool & Spa
Why is the Jandy RS6 Intellitouch Controller Extra Aux / Solar power plug always ON/Powered?
Your logic seems workable...
(I got nothing ... should work).
Trouble shooting says to check & clear "phantom"
programming... (Pg. 30: sounds like hokum 2 me).
My best advice..
Go to page 40 and contact their customer support.
Jandy AquaLink RS Installation Manual Warranty
1-707-776-8200
Carnac the Magnificent
Jun 22, 2014 | Jandy AquaLink RS All Button, Wired, RS6...
Why is jandy rs6 solar always on
assign the solar in the setup to a aux power the lights from the aux that you assigned
Jun 22, 2014 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Aqualink RS6, 6700 rev c message
check to see if wires are cut or shorted if ok need new controller
Apr 30, 2012 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
572 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
