Question about Bosch Integra® 500 SHX46L Built-in Dishwasher
I have bosh dishwasher model shx46 is stak on demo cycle
    Sergeant:
    Champion:
  • 263 Answers
Lol
There is not demo cycle. Most likely your board went out and it just keeps running all the time. (common problem)
Bosch dishwasher repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Bosh washer won't stop? model SGS45C02
major recall of bosch dishwashers. recommend you check the list. https://www.consumerreports.org/dishwashers/maker-bosch-expands-dishwasher-recall/
Jan 01, 2018 | Bosch SGS45C02 Dishwasher
I have a KitchenAid model KUDP01FLBT6 dishwasher. When hitting the "Normal" button and the "Start" button, the dishwasher would run for less than 5 minutes and then shut off. Dishes...
what makes you think it was in a demo mode ?? was it a floor demo model ? as if it was there might be a few things you needed to reconnect before you use it in your home , one that comes to mind is the float level switch , this is usually in front right corner and demo models usually have a foam spacer under there edge , also its possible a demo model could have a special control board in them , requiring you to replace it with a standard model b4 it would work properly
May 27, 2017 | KitchenAid 24 in. KUDP01FL Built-in...
How can I clean my cloudy glasses? How can I stop my glasses getting cloudy?My Bosh model is "Bosh Classixx"
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 04, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My bosch shu5306uc / u12 doesn't fill with water and it ends up making a growling noise after running - will run forever and never cycle....
DANGER stop using your dishwasher HEALTH CANADA WARNING Health Canada has forced Bosh to recall SHU 53 models. Risk of fire see link below.
http://cpsr-rspc.hc-sc.gc.ca/PR-RP/recall-retrait-eng.jsp?re_id=631&searchstring=&searchcategory=&searchyear=&StartIndex=1&current=true
Dec 22, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a 4 year old Bosh dishwasher, model=SHX43C. It is supposed to have a 80 minutes econo-cycle and a 105 minutes regular cycle, but all of its cycles are 4 hours (!) now. My incoming water temperature...
Elements Could be faulty, or timer on pcb could be sticking. I'd check elements first. Make sure they are clean and not scaled up and check for resistances
Jan 07, 2018 | Bosch Dishwashers
Bosch dishwasher SHX46 won't fill with water
My model is actually a SHX46 but I was able to piece together some advice off of this site. This is what I did. I removed the toe plate and then I soaked up all the water that I could out of the white pan at the bottom. Then I unhooked the water supply line so that I could pull the dishwasher out. Once I got it out, I tipped it forward to drain out the rest of the water. I then unhooked the drain line that was connected to the disposal and cleaned it out with a "Snake line" I then hooked everything back up and it worked. Thanks so much for this website, I know it saved me a ton of $$$$$$$$$.
Jan 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Integra® 500 SHX46L Built-in Dishwasher Logo
339 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
