Question about American Standard 2294.011.020 Afwall Elongated Wall-ADA Retrofit Toilet
Toilet handle stick on flush and water runs and runs before we are aware of it
    Problem Solver:
  • 19 Answers
Turn water off and get a handle repair kit, very easy repair
Posted on Mar 02, 2010
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
The lever (handle) to flush the toilet does not rise after it is pushed down, causing the toilet to run. One has to push the lever (handle)up after the down motion to make it function properly.
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Nov 08, 2010 | Toto Home
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
I have a Eljer 150-403 and the toliet will not flush, although the handle is able to be moved down
Remove the tank lid and set it aside. Inside, you should see where tha handle passes into the tank. There should be an arm running along the inside of the tank that raises when the handle is pushed down. Attached to the end of the arm is a chain that goes down into the water and attaches to the flapper valve. Now that you have identified all of these parts, push down on the toilet flush valve, and you should be able to identify where the toilet is broken. It is most likely he flapper or the chain.
Shut the water off behind the toilet, at the wall. Slowly stick your hand into the tank, and raise the flapper. (Don't worry, this is clean water).
Let the water drain through the toilet, and make your repair. All oarts necessary are available at any hardware store. Take your old part with you.
Best regards, --W/D--
Aug 11, 2009 | Home
Toto toilet ultra max flush
Open the tank and examine the linkages between the handle and the flapper. If the handle is sticking, it sounds like there may be either mineral buildup or a stuck chain.
May 27, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
SHOWER HOT WATER SCALDING
hi as you are probably aware ,when the toilet is flushed the water pressure to the shower is reduced so you get hot/scalding water unfortunatly there is NO easy solution you could put a needle valve in the supply to the toilet and with trial and error by turning the valve down reach a compromise between the time it takes to fill the flushing tank and the shower temp the only real solution is to feed the toilet and shower off independent supplies but in most houses this is impractical if not impossible silk090
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
American Standard 2294.011.020 Afwall Elongated Wall-ADA Retrofit Toilet  Logo
434 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
