Question about Trg Pixo Corion C700 (Black) Monitor
None of the speakers work - Trg Pixo Corion C700 (Black) Monitor
    Sergeant:
    Champion:
  • 265 Answers
Did you connect the sound cable to the line out of the audio card?
Posted on Feb 06, 2010
Avr250. Right speaker half working
There could be a wire broken off from a terminal on the speaker. The capacitor that goes to that speaker could be defective. Lastly, the speaker itself could be defective. Those are the only three reasons why one of those speakers are not working. None of the repairs are that difficult to do, if you are a do it yourself type of person.
Jun 08, 2014 | Audio Players & Recorders
I have power to my radio deck (which is after market) BUT none to the speakers, is there an amp in the 2001 pontiac aztek
The blue wire from your aftermarket radio that connects remote for a amp has to go to factory harness purple wire there is two purple wire so you need to try either or and it will work i just did one on an 2004 aztek
Jul 02, 2012 | 2001 Pontiac Aztek
My rear passenger speaker wires don't work, I have connected 3 different speakers to them none of them work but those 3 speakers work when they are hooked up to different connections.
have you tried connecting directly to the radio? I would suspect a broken wire or a bad fader control or switch depending on the model.
Jan 31, 2012 | 1998 Ford Expedition
The rear and centre speakers are not working but the front and subwoofer speakers are working. What do I need to do to get the three working. In the booklet it says the rear speakers might not work becasue...
From them manual Troubleshooting section:
"When listening to a CD or radio, sound is output to the front
speakers (L/R) only. Select "PRO LOGIC II" by pressing
PL II (Dolby Pro Logic II) on the remote control to use all
six speakers.
• Make sure that the DVD disc is 5.1-CH compatible.
• If you set C, SL, and SR to NONE in the speaker mode in the
audio setup of the setup screen, no sound is heard from the
center speaker and the rear left and right speakers. Set C,
SL, and SR to SMALL."
This means you might want to check your speaker settings again and make sure the Cenyer and Surrounds are defined.
Feb 27, 2010 | Audio Players & Recorders
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
When i turn on my receiver, it starts up for a second and then it turns itself off. thoughts?
first of all , check all your speaker wiring make sure none are touching acrros(frayed) . if good disconnect 1 speaker at a time and turn on unit . if it stys on you found your problem- a shorted speaker.
If none of these things work, disconnected all speaker aand check with a volt ohm meter( you can get a cheapie at Radio Shack)- acroos each speaker you should have either 4ohms, 6 ohms or 8 ohms, depending on the rating on the back of the speaker. if any read lower, replace speaker.
If all else fails, go to yamaha.com/usa and go to support, call service center for repair listed on site.
hope this helps ! Steve A.
Jan 02, 2010 | Yamaha HTR-5760 Receiver
Only the front speakers work none of the surround speakers
If you are still covered by the warrenty, then you may be able to get it fixed at no cost.
Otherwise get a qualified technician (I say this to cover my but rather than suggesting that you open it up yourself) to open it up and check the fuses inside.
Aug 17, 2009 | Onkyo TX-SR705 Receiver
None of the speakers will work different
best bet is to wire back up the factory wiring harness end then go to walmart or to autozone and buy a 10 dollar wiring harness. It is specific for the vehicle. It will plug into your wiring harness then matches color to color with the back of an aftermarket harness. Trying to match everything up is a gamble and it takes 20 times longer. There's no thinking to the other harness.
Jun 06, 2009 | Car Audio & Video
None of the speakers on the right side of truck work
The first step is to make sure the "balance" on the sound system is centered and not shifted all the way to the right. Contact me on FixYa if I can be of any more assistance. Thank you.
May 26, 2009 | 2002 Ford Excursion
Trg Pixo Corion C700 (Black) Monitor Logo
Top Trg Computers & Internet Experts
David Payne
David Payne
Are you a Trg Computer and Internet Expert? Answer questions, earn points and help others
