Question about Maytag Neptune MAH5500B Front Load Washer
It says the door is not locked
I close the door, and I can tell it is locked. I push start and it locks and the door locked button blinks and then goes off and it will not turn on. Helo?
    Sergeant:
    Champion:
  • 263 Answers
There are two switches in the door latch and they both need to engage. Check it with voltmeter. Most likely bad door latch assy.
Maytag Neptune repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
Ford f150 door lock
Try disconnecting the lock switches. It could be one of them is shorted closed.
Aug 20, 2017 | Cars & Trucks
Machine will not start dL code flashes
The door lock is not telling the control board the door is locked. You probably have a bad door switch or the wires to the door switch are corroded or broken.It could simply be a wire has come loose. Those washer do vibrate quite a bit.
Apr 16, 2010 | Washing Machines
Ford Mondeo rear brake pads replacement
I have ford mondeo ghia 2002.
when i press the button on the remote-key, I can lock and unlock the powerlock (in the door).
When I press the button un the door, not all doors are locked.
What's the reason?
thnak's
Sep 17, 2009 | Cars & Trucks
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener problem
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi, I have a duet washer that won't turn on. The "Control On" button is blinking and when I press the "Hold to Start" button, nothing happens. And ideas?
Open and close the door.
The door has to be opened between wash cycles.
Check the door switch/lock unit
using the diagnostics listed below.
If door is locked, Drain the unit.
Check wire harness for connections.
Check the touchpad/LED assembly.
Starting the test mode:
Close the door
Press Control On button
Select the DRAIN/SPIN cycle
Select NO SPIN by pressing the SPIN SELECT button,as needed,
Push Prewash Option button 4 times within 5 secs.
C:00 will show in the display.
To advance to the next step
Push Prewash Option button 2 times.
Here are the codes:
C:00 check door lock system actuator
C:01 Check cold water inlet valve flowmeter
C:02 check dispenser motor
C:03 check hot water dispenser
C:04 check basket rotation MCU,Motor
C:05 check heater sensor
C:06 check Drain pump
C:07 check Motor or motor control unit
C:08 check Motor, MCU control
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Light blinking
click this link if you get any error or any light blinking on the pannel and the unit does nor works
http://www.applianceaid.com/frigidaire_frontload_washer5.html
thanks
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
