Question about Bosch SHV68 Built-in Dishwasher
Bosch SHV68M has a red faucet that appears on display after it runs about five minutes
  • richardselec Feb 08, 2010
    It is definitely a red faucet that appears in the upper left corner of the display. It is none of the symbols you had shown. It doesn't seem like the water is very hot , even when you run it at the sink first.
  • 506 Answers
I believe it is an incoming water temperature sensor. Have you recently changed the temperature of your hotwater tank? You may want to contact Bosch regarding this. You may also have a problem with the internal water heater.
Posted on Feb 08, 2010
  • Bosch Master
  • 19,396 Answers
Hi.
As far as I know there is no red faucet error on Bosch dishwasher.
Ensure that the symbol is not one of the following:
The symbols above are all displayed normally in cycle and do not report any error.
If the machine is not completing the cycle, then start tripping the circuit breaker, then do the following:
In case this is an error belonging to this particular model, and not being reported on manual, check the following.
Check if water is getting inside the machine
Check the inlet hose, ensure that there is sufficient pressure, and that the hose is not kinked or blocked.
If that is not the problem, then it is usually a faulty water level sensor, not detecting that enough water is getting into the machine.
The error can also be triggered by a defective inlet valve, but that is uncommon, as in that case there is no filling.
Check if there is water getting inside the machine in first place.
Here also the manual.
Posted on Feb 06, 2010
Set clock 08 fxdwg
Turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
May 02, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
How to reset clock on 2010 softail deluxe?
Apr 26, 2014 | Harley Davidson FLSTN- FLSTNI Softail...
My Bosch does not wash well
Clean Your Dishwasher with Tang (yep - the citrus drink)
  1. Empty the dishwasher.
  2. Run the water in the kitchen faucet until it is hot. (He suggests you do that before running your dishwasher every time.)
  3. Turn the tap off and start the empty dishwasher.
  4. After two or three minutes, stop the dishwasher and add a container of Tang.
  5. Let it run the whole cycle.
Jan 01, 2014 | 1993 Mazda RX-7 Brake Pad Set Bosch
Water is way too hot. Five year old GWH2400E NG is giving error code EC: Ionization failure during operation. set point temperature = 106, inlet water temp = 88, outlet water temp = 171, water flow = 12,...
Before calling service technician who has service manual and can test which part has failed, open following links for troubleshooting resources including steps below and phone number for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ETechSupport/Troubleshooting/tabid/1131/Default.aspx
Clean inlet filter
Check all faucets for clear pathway
This unit does not work with preheated water (solar assisted)
Incoming water above 70 degrees, avoid restricted faucets
Check that both temperature sensors are making contact and firmly mounted on respective cold and hot pipes.
Descale heat exchanger
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G2-13_Descaling.pdf
Aug 16, 2011 | Bosch AquaStar 2400ES-NG
How do i set the clock in a 1992 buick century with stock radio
To set the clock, check this procedure:
1. With the radio ON or OFF, press SET. The SET indicatore will appear on the digitas display for five seconds.
2. You must begin to set the clock to the correct hour and minute during those five seconds. Press and hold SCAN until the correct hour appears on the display.
3. Press and hold SEEK until the correct minute appears on the display.
Hope help with this, remember rated this post, and TY for using Fixya.
Apr 15, 2010 | 1992 Buick Century
Makes low rumble noise when 2 or more faucets running hot water. New installation. Inlet vent: 3 feet with 3 Ls. Outlet vent 3 ft with 1 L. Gas: 3/4" all the way(no flex).
CALL BOSCH TECH SUPPORT, THE NUMBER IS BEHIND THE COVER, THERE ARE A SERIES OF DIP SWITCHES FOR THIS WATER HEATER THAT HAVE TO BE SET ACCORDING TO YOUR ELEVATION, VENT LENGTH, AND USAGE. THIS IS FIVE MINUTE FIX.
Nov 19, 2009 | Bosch AquaStar 2400ES-LP
We have a Bosch dishwasher model SHU5315UC/U06. When we ran a "Regular Wash" the dishwasher ran continuously and the timer did not count-down. None of the Delicate or Rinse and Hold buttons responded. ...
My father-in-law has a Bosch and they had the same problem. The tech guy said it was not heating properly and that caused it to continously run because it won't tick down the timer if it doesn't reach a certain temp, so try turning your faucet as hot as you can, right before you turn on the dishwasher and see if that is the problem, if not the heating element might not be working properly. If you still have a warranty, try to get them to see and fix it, otherwise, get a repairman to check it out. You can also turn up your hot water heater, but not so hot it would be dangerous to use, but enough to get the temp up. Otherwise the heating element might need to be replaced.
Jul 28, 2009 | Dishwashers
Machine is beeping and a faucet is appearing in the panel
I just fixed this fault on my SHE68m05uc. The fault lets the machine run through any cycle and every ting else was working properly. In line between the fill valve and fill float assembly there is an electro magnetic impeller which is "open" if there is no water flow. the signal goes to the timer control board on the lower right side of the machine. If you Pull the impeller, take an OHM reading across the sensor that is mounted to the side of the impeller and blow into one end. If the measurement changes as it rotates, its good. if its shorted "0 Ohms" its broke. The part was about 17$
Nov 20, 2008 | Bosch Evolution 800 SHE68M05UC Stainless...
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Bosch SHV68 Built-in Dishwasher Logo
2,183 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
