Question about Maytag Neptune MDE7500AY Electric Dryer
MDE7500AYW Neptune Dryer came back with some type of sensor message like sensor off and will run for about 2 minutes and then cut off
  • 572 Answers
Might need the mother board
Posted on Feb 06, 2010
Why does my dryer end its cycle early?
depending on what type of model. there is a moisture sensor inside the dryer. when you use any cycle other than time dry. if it is a small load ( 2 -3 shirts) it may not touch that cycle. making the machine think that things inside are dry and cut the time short. you can try time dryer and see if that helps. to check if moisture sensor on you dryer is working some models will have a test mode to make sure its sensing. try pressing more time button, then less time button back and fourth. all lights should come on. then you can open door. and when put your hand across the moisture sensor usually near the lint trap. you should hear a beep. to indicate that its reading moisture, meaning good..
Sep 19, 2017 | LG DLG5988 Gas Dryer
Hello all, My MDE7500AYW Maytag Neptune Dryer was working today and just quit. It is plugged in and the drum light works when the door is open, close the door and nothing. No LCD display, no...
looking at schematics looks like you main control board is the faulty part. you have done a very good job of tracing the voltages from the source. been that all voltages are present and door switch is good the part left is the control board. here is the part# 33002886. you can find it at sears website or service center.
good luck to you.
Feb 15, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Replace drum baffle on Maytag MDE7500AYW dryer
When you open the door of the dryer you will find screws on each side. First remove the screws that hold the door on, then move to the next side. Once the screws are out you should be able to lift the front panel right off. Let me know if you have any other questions and let me know if this was helpful to you. Good luck and I am glad that I could help.
Jan 22, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MDE7500AYW - Won't start - Message says "A power failure..
I had the same problem. It turned out a power transformer in the neighborhood had gone bad. I found it by checking power at the receptacles in the house and we weren't getting proper voltage throughout the house. We had enough power in the house to power lights, the TV, coffee maker etc. but not enough for the dryer. I called the power company and they came out to do a check. At first they said there was a wiring problem with the house until all the neighbors started coming over after seeing their vehicle and saying they were having problems. So maybe you aren't getting proper power to the unit.
Good luck. Hope this fixes your problem.
Oct 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer spins but no heat
Did you check the power coard where it connects to the dryer? Start at the source. Make sure that you have at least 110v on each line. The dryer will tumble on 110v but requires 220v to heat. If you have 220v then check the t-stat and thermal cut-out on the blower. Check all wires for loose or burnt terminals. If all that is good it may be a bad motor or timer/control. I'm happy that you have a meter.
Good luck.
Dec 17, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Maytag neptune dryer
could be the heater element, check for circuit with a test meter if it does not heat up in the minute it runs this is almost certainly your problem
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Maytag Neptune dryer error
To find out what the code means,
contact Maytag ServicesSM, Maytag Customer Assistance: U.S.A. 1-800-688-9900 or
Canada 1-800-688-2002.
Maytag Neptune MDE7500AY Electric Dryer Logo
117 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
