SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
SOURCE: microwave stopped nothing works fan lights buttons over counter ge spacemaker model jvm1630
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and
put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: ge spacemaker microwave has no power how do i change the fuse?
First you have to unplug your device. Next you must remove the cover from the micowave. Follow the powe cord to the unit the fuse should be right at the beginning of the powe cord. I hope yhis will help you.
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
