Question about Gateway FPD1975W 19" LCD Monitor
Blue led is flashing, won't turn on? - Gateway FPD1975W 19" LCD Monitor
  • 3 Answers
Check its power output for any short.....
Posted on Feb 07, 2010
How to do a hardware reset for LS-XL?
Turn off the LinkStation. 2. Turn the LinkStation on with holding down the function button. The function LED will flash blue. 3. Press the function button again while the LED is flashing.
The status LED will flash blue. It will start flashing amber when initialization begins.
Aug 24, 2014 | Buffalo Technology Buffalo Linkstation...
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
Hp altec Lansing laptop won't turn on
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 10, 2012 | Sony VAIO R505JL Notebook
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
PHONE WON'T TURN OFF
For Nokia 6300
  1. Remove the battery to turn it off then insert it again.
  2. Press the power button. The blue LEDs on the sides should flash and the phone turns on.
  3. If the blue LEDs do not flash, you have a broken power switch.
  4. If the blue LEDs flash but the phone does not turn on, you have a weak battery or hardware/software problem.
  5. If the battery is good, have your phone checked by a qualified technician.
Nov 29, 2009 | Nokia 6300 Cellular Phone
Hi, I have a 60VS810 60inch LCD projection. Normally when i turn on the TV, theres a blue led that flashes, and when the blue led turns solid, the screen picture appears. My problem now is that the blue...
It could possibly be the power supply unit or the lamp.The power unit is HA01331. cost is about $120.The lamp is UX21514 cost about the same. Hope this is helpful.
Oct 23, 2009 | Hitachi 60VS810 60" Rear Projection...
I have a creative zen mp3 player.It won`t charge in my computer but the blue LED is on but the screen is black
i have the same problem i let it die completely, and then i plugged it in and then the screen was black nothing but the blue LED is on but it flashes...please help i just got this a couple of months ago!!!!!!
Sep 21, 2008 | Audio Players & Recorders
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Gateway FPD1975W 19" LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
