Question about Swiss Army Wenger Sportedge Bracelet Watch
Wenger field chronograph only works when not in use
Field chronograph model 79110 works when not in use,stops working when worn.it may run slow or just stop.when i reset it a couple of times it will stay working all day and never skip a beat.i have to do this routine daily. the watch is only a month old and i have replaced the battery thinking that was the problem.
    President:
  • 2,501 Answers
Take or send it back to your supplier, with an explanation of the problem.
Posted on Feb 07, 2010
My wenger sport elegance chronograph watch stopped working after 2 months. I bought it brand new. After readjusting the time, it worked for about 8 more hours, and then died again. The small dial on the...
You should change the battery, it is the cheapest thing to try. The batteries can be very old before they are installed and could have been in the watch a long time before you got it.
Sep 30, 2013 | Wenger Sport Elegance Chrono White Dial...
Why isn't the second hand on my Wenger Commando SR not working? The red seconds hand is not moving. The small seconds counter of the chronograph works and the minute and hour hands work.
The large seconds hand will remain at 12 unless you press the upper right button to start it. Pres again to stop it and press the lower button to reset it. The small seconds hand that always runs is the seconds for the time. The large seconds hand is for the stopwatch function. If you like to have it running all the time just start it and leave it running - it won't harm the watch.
Jun 02, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Hi, I recently purchased a Wenger Commando Chronograph Special, and on several occasions now, the battery seems to have stopped. Is this due to it being brand new or should I send it back? Many thanks
If it is still within the warranty period, it sounds faulty and should be returned to the supplier.
It might be helpful if you spoke to your nearest dealer first to make sure that it is a fault.
May 04, 2010 | Swiss Army Wenger Commando Chrono Men's...
Seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Apr 29, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Stuck second hand
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
Feb 26, 2010 | Swiss Army Wenger Commando 70728 Wrist...
Reset Chronograph
Go to "www.wengerna.com/commando-watches".
There are several models of our watch. Choose yours and click on the picture. Details of the watch will appear and "product manual" is listed for you.
Feb 20, 2010 | Swiss Army Wenger Commando Chrono Men's...
The second hand on my chronograph will not index properly when reset
Try this or some variation as it worked with my new Wenger Chronograph.
Pull the crown out to the first position (for changing the date) and press the top button - one of the hands - either the big second hand, the little minute hand, or the little tenth of seconds hand - should move one notch. Keep pressing until it reaches the desired position. Now press the bottom button, same process. Pull the crown all the way out and press the top button, same process. Then if that still hasn't solved it, crown all the way out and press the bottom button. Each position should correspond to a hand, and each press should move it one notch. When settled, push the crown all the way in and operate it normally.
Be careful not to press buttons when changing the date or time, and don't bang or shake the watch too hard while using the chrono. Also, don't play with the buttons or press them one after the other too quickly.
Oct 30, 2009 | Swiss Army Wenger Wenger watch
The second hand stops on the minute hand
If the hands are binding the movement needs to be removed from the case and the hands set right. i.e. parrallel and not binding.
Jul 18, 2009 | Swiss Army Wenger Swiss Army Officer's LS...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Swiss Army Wenger Sportedge Bracelet Watch Logo
393 people viewed this question
Top Swiss Army Wenger Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you a Swiss Army Wenger Watch Expert? Answer questions, earn points and help others
