Question about Samsung Digimax S630 Digital Camera
How do i set the timer?
How do i set the camera to take a group photograph without someone actually having to capture it?
How do I set the timer to take a picture?
Solved---found the manual and downloaded it
Posted on Feb 23, 2008
After you turn on your camera and you want to take a group picture, look near the MENU button. in the right side of it you'll see a timer. you can set it to 2 seconds or the number of seconds you choosed in the setup.
Posted on Feb 22, 2008
How can I take a selfie?
should have checked it out better before buying EH guess you live without selfie''s
Apr 24, 2015 | Motorola Cell Phones
What settings should I use for shooting at a concert, lighting will not be a problem
The settings depend on the type of picture you want. Since you declined to specify the model of your camera, I can't give you any exact answers.
If you want an overview of the entire scene, the stage, the performers, the audience, etc., you can treat is as a landscape. Use a small aperture to get maximum depth of field.
If you want to catch a single performer or a small group of performers in motion, treat it as a sports scene. Use a fast shutter speed to freeze the motion and a large aperture to narrow the depth of field.
If you want to convey a sense of motion, use a slower shutter speed and let the action blur.
The camera is a tool. You're the photographer. YOU have to decide what you want your photo to say to the viewer and use the appropriate settings to capture that. Two photographers shooting the same thing with the same equipment will most likely be using different settings because each will have his/her own view of what the picture should say.
Feb 05, 2012 | Canon Cameras
I have sony DSC-S500 digital camera i want to know how to take a photograph using self timer thank you Regards Sailaja
For capturing the images using Self Timer, press the Down Arrow control button continuously to select the desired mode. You can set the timer for 10 seconds and 2 seconds by pressing the continuously, If we press the button again the Self Timer will be turned off.
Press the Shutter button, the self-timer lamp flashes and a beep sounds until the shutter operates. To cancel the self-timer, press the down arrow button again. You can redice the risk of blur by using the 2-second delay self-timer.
Good Luck!
KenSolutions
Oct 30, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
FOLDER CONTAINS NO IMAGES.
Please follow the instruction below and let me know what is happening.
1. format the new card.( Can't format is from any virus
infected PC ).
2. Insert the card then reset your camera setting.
3. select your mamory card default for save the
photographs.
4. Before start photography confirm that your battery
is fully charged.
Thnaks & please give me feedback about your camera.
Feb 03, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
My camera turns on but the capture button stopped
Be sure you have fresh batteries or fully charged rechargeables. Go into the camera menu and find "reset"...follow the on-screen instructions.
Dec 31, 2009 | Samsung Digimax S630 Digital Camera
How do i put shutter cable on, or how do i remove the button
You can't. Not without destroying the camera. There's a clever little gadget from UK letting you use a generic cable release to "any" camera:
http://www.firstcall-photographic.co.uk/shop/categories/camera-accessories/0/firstcall/firstcall-cable-release-adaptor-bracket-for-slr-cameras/
Or, you can use the self-timer to prevent camera shake. You have to set the self-timer for every single shot, tho...
Oct 23, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Using automatic timer to take group photo
Press the bottom part of the square with the "OK" button in the middle. It has a picture of a clock. "Off" will be highlighted, so scroll down to the picture of the clock, and it will show the message "Selftimer On: A photo is taken automatically 12 sec. after shutter button is pressed." Press the OK button to activate this mode. Now it's just like taking a regular picture, just press the button and run over to the group and in 12 seconds it will take the picture.
Jul 07, 2008 | Olympus FE-210 Digital Camera
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Mavica cd300
The camera is not megabytes (MB) but megapixel (MP), there is a big difference. If you multiply the horizontal resolution by the vertical resolution then that will be how many megapixels are being captured. So in this case, max resolution 2048 x 1536 = 3145728 which is 3.1 MP effective. I don't think any camera actually captures exactly the full MP listed on the camera. Now, if each pixel was represented by a byte then you would have 3.1 MegaByte picture captured. However, each pixel is represented by I think 3 bytes which would give you a 9.3 Megabyte picture captured. However, since this is usually to large for most users to deal with, compression is introduced thus the settings for fine and standard. The tiff picture type is the 9.3 Megabyte photo with no compression. For most of us this isn't very effective for working with so we use the jpg compression. This reduces the picture to a more manageable size for saving, manipulation and storing. Keep in mind that this is what is called a 'lossy' compression which means that it actually removes pixels from the photograph and uses a technique called interpolation to bring the pixels back later.
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
Samsung Digimax S630 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
