Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Blue and yellow ghosting and top and bottom bows alittle blue and yellow tried magic focus didnt help
  • 10,594 Answers
Symptom shows it is convergence out chips failure problem that are causing blue and yellow ghosting and bows picture on tv screen.
Replace convergence out chips in tv, problem will be be fixed.
Let me know exact model of your TV to provide you more detailed info if you want to repair it by yourself.
Thanks.
Posted on Feb 06, 2010
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 03, 2009 | Hitachi 53FDX20B 53" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
HITACHI DIGITAL ULTRAVSION HDTV PROJECTION TV
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Dan
Jun 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
53swx10b bowed picture
Double check your work for errors such as solder bridges or incorrect resistor placement. Look carefully anywhere solder could have dripped or splattered to cause the bowing. If you entered the digital convergence mode to touch it up, you will have to re initialize the magic focus for it to function. Good luck
Mar 12, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Blue and Ywllow ghost
Hi, you need to replace the convergence IC`s and any burnt resistors in front of the IC`s, common with all big screen rear projection tv`s, if you attempt to do this yourself be sure to get original IC`s or your just wasting your time, and it will take you 2 hours easy, any questions email me back, BMW Rider
Dec 24, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Blue shadow
Needs convergence circuit repair = replace convergence IC's,
then activate Magic Focus...............need step by step?......T.
Nov 30, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
