Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Can't connect a PC to internet via rangemax
I have set up the rangemax OK, and have 2 PCs working fine. I have now added a third PC, and it apparently is connected OK. However, i have no access to the internet with it. I am using IE 6. The netgear setup website recognises only two PCs, but not the third, even though the PC says it has a good connection. Any help would be gratefully received. Thanks.
  • 1 more comment
  • Jazzelad Feb 22, 2008
    all pcs are wireless. 2 of them similar IP addresses 192.168.1.2 & 192.168.1.4. When automatically assigning an IP address for the 3rd machine, it comes up with a really high number which according to Netgear's web site is out of range. I tried setting it manually to 192.168.1.3, but still no internet. The Netgear site recognises the machine as being connected but still no internet. I have tried copying the settings from a different machine and when reviewing all the settings using the Belkin Wireless USB monitor there is a message saying DHCP: "Disable" even though it shows all other setting as OK. The Belkin monitor shows good connection between the PC and the Rangemax, but the signal is going no further to the internet
    According to the config page, the IP address is got dynamically from ISP. In the LAN IP Setup, it says "use router as DHCP server" with a starting IP address of 192.168.1.2 and an ending IP address of 192.168.1.254. I assume this means that there are 250+ IP addresses assigned - although this is in the LAN IP Setup. I can not find any mention of DHCP in any of the wireless setup pages. Hope this helps.
  • Dan May 11, 2010
    Are all PCs wireless?
  • 46 Answers
Sounds like the network card on the 3rd computer might be set to a manual ip address. Is the rangemax router the dhcp server? if so is the network card on the 3rd computer set to obtain an ip address automatically?
can you tell me the ip address of the rangemax router?
whats the ip address of the 3rd pc?
Thanks,
Brad
Posted on Feb 21, 2008
  • Brad Nelson Feb 22, 2008
    Ok now we are getting somewhere. It appears your 3rd pc is not communicating with the dhcp server to get a valid ip address.
    I recommend logging into your routers config page and make sure dhcp is turned on, and that the minimum number of assigned ip addresses is more than 10. its quite possible if your wireless security is open that people have stolen your internet and used up the assigned ip addresses and your router is not assigning anymore ip addresses. Take a look at those settings and let me know how it looks.
    Thanks,
    Brad Nelson
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Aug 30, 2009 | NetGear RangeMax WPN824 Router
Rangemax-internet only works when comp directly connected via LAN
it sounds like you have the wireless connection to the WAN disabled. Go through the wireless settings on the router and check to make sure it's not being blocked from the WAN/Internet connection.
Nov 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
Net gear router won't install properly and will not let me use the internet
You may want to try:
  • If both your router and modem have DHCP features enabled, disable the one in the modem;
  • manually set the Internet/WAN IP add of the router to follow the IP add of the modem;
  • manually set the default gateway of the Internet/WAN side of the router to use the IP add of the modem;
  • set the PCs connected to the router to automatically obtain IP adds.
  • verify that the PCs uses as their default gateway the IP add of the router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 12, 2008 | NetGear RangeMax WPN824 Router
Only showing as a network device on 2 of the 3 pcs on the network
Did u added the new network devices, or did u wait till thy popped up?
If u didn't added them manually, then go to networklocations, add network location, press next, and again next, then type in \\mybookworld\"here the name of the folder of your mybook, ex. Movies or music,.." (without " ")
Do it for every folder.
Oct 07, 2008 | Western Digital 500GB My Book World...
How to setup an adsl modem and a router
forget the router as it appears that it is messing with the connection
May 13, 2017 | Cnet CNIG914B 4-Port 10/100Mbps Router
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
LG 32LC2D Power light Blinks but set will not power on.
change your adc(analog to digital converter) board will help out
Jan 30, 2008 | LG 32LC2D Television
HTTP dropout issues
Hi, From initial/apparent indications, it would appear that something was changed in your netgear configuration that affected your internet connection. This would appear likewise to be reinforced that by resetting the router, your back to normal internet connection (though for 'bout 30 mins) and then you'll get disconnected again. Though am not discounting the router error, why don't we try a process of elimination to zero in on the problem. Client side: 1. The usual checks, virus scan? ad scan? any update/upgrade/change of your browser? 2. In your Internet Options/Advanced, try checking Use HTTP 1.1 through proxy connections and in your Connection/LAN Settings, check automatically detect settings; 3. Have you tried Networking Repair, Release, Renew? 4. Does the dropout happen both to wired and wireless clients? 5. Can you try assigning fixed IP add to your client PCs (both wired/wireless) starting from 192.168.0.2 then + 1 to all others thereafter, Subnet Mask is fixed at 255.255.255.0, Default Gateway at 192.168.0.1 (or whatever it is that you have set the NetGear IP add to be), DNS what ever is being used by your ISP. On the router side: a. Was there any firmware update recently? b. Try without any security (WEP, WPA, MAC filter) just to be able to determine if it is related; c. If possible, set router WAN's DNS also to fixed and not auto obtain; Give your provider a call, the problem might be with them. To cite an example, we have 3 local ISPs. One of them has this problem that on certain times of the day, their client would appear to be connected but can not open any site. What I did was to enter the DNS numbers of all 3 providers to the client's PCs though the client is only connected to 1 provider. No more dropout. Am not saying this will work for you merely to give you an idea. Hope this be of some help to you. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
94 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
