Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Hello my router keeps going offline, what could be the prob. do i need to update it??i have to unpluge it and it starts fine again until it just goes off.its in a ventillated place.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 34 Answers
If this keeps happening after a reinstall or reboot I would suggest calling Belkin (India), that's what I had to do when I used their products, in the end I switched to Linksys and have had no further issues.
Posted on Feb 06, 2010
  • 163 Answers
Have same problem with my D-Link router, try re-installing it.
Zyxel router P - 330W EE continuously overloads and disconnects from the internet
mainframe computer? You have a business? Your ISP may be "throttling" your data.
Jan 04, 2013 | Zyxel Computers & Internet
Ps3 keeps saying restoring database it stops at 40% and after like 1 minuite it goes to 100% then it does the same thing again by saying restoring data base.
Hello
Try a router reboot.
1 power down ps3 and any pcs or laptops.
2 Unplug all cables from router.Including power for 1 min.
3 Plug all cables back in the router and power up.
4 Try ps3 again.
Another solution is some data on ps3 may be corrupt.You would need to do a restore of ps3.
You will losse all info stored in ps3 such as username passwords and accout numbers.
So write it all down if you can.
1Turn off ps3 with switch in back.
2 Turn back on,hold power button until you hear 3 beeps.
3 go through setup until prompted to format.
4 Then format.
This operation can take as long as 1 to 3 hours.Also you will loose all info you put into ps3.
Sep 22, 2011 | Sony Playstation 3 (PS3) Console
Our brother hl-4070cdw worked fine with the wireless connection until some weeks ago.. now even if printer settings are all correct - it says it is offline... restarting the router will then make the...
It could be a router issue. Try resetting the router and see if that will fix the problem. Look for your router's reset button, can usually be found at the back of the router, then use a pin to press and hold it for about 15 seconds.
Sep 14, 2011 | Brother HL-4070CDW Printer
Bought router in 2009 and worked fine up until about a month ago. Every couple of minutes will disconnect. Wireless connect on laptop shows it is connected. I get page not found. Soon as I unplug it...
try updating the firmware to the latest version.
http://en-us-support.belkin.com/app/answers/detail/a_id/306/~/f5d8236-4-n-wireless-router---firmware
it may fix any bugs or wireless issues in the update.
Apr 05, 2011 | Belkin F5D8236-4 Router
Hp 4650dn printer showing offline. Connected through airlink router. Working fine one day, offline the next. Power cycled and checked all connections, still no luck.
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Jan 06, 2011 | HP LaserJet 4650dn Printer
Hello. My printer keeps saying Offline. I try to change it to Online, but it won't change. The printer was working fine until I ran out of paper. When I put paper in the printer, it decided to put itself...
You can fool with it and make it work ... I suggest you remove and reinstall the device for best results. If you dont have the software, go to HP.com/support and get it. They may even have updated version for you.
Good luck with this.
a
Oct 05, 2009 | HP DeskJet F380 All-In-One Printer
Asus Router Offline
hello!
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
Mar 08, 2008 | Linksys Wireless-G WRT54GX Router...
How to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Oct 12, 2007 | Brother MFC-8860DN Printer
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
97 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
