Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I just changed the worm gear on my craftsman 1/2hp garage door opener.. i put everything back the way it was, press the remote button to pull up the door but the chain pushes the opposite way for a second and then pulls the door up about 6 inches off the ground. i press the remote button again and the garage door repeats the same process. What is wrong?
  • cameron_slow Feb 07, 2010
    i adjusted the limit switch but it doesn't act any different than before. The motor pushes the door down about a foot and then pulls it back up a foot. the eyes on the bottom of the garage door act as they should. i know today is a sunday but if you have time can you give me a call and try to talk me through a couple of trouble shooting ideas? my number is 512-799-8786. thanks for your help.
  • cameron_slow Feb 08, 2010
    i appreciate the help Jerry. you had solution for my problem and presented it to me in a very timely manner.
  • 244 Answers
SOURCE: motor runs but gear doesn't turn on my Craftsman 1/2 HP
What did you pay for near gears. curious. often get stripped gears in cold weather as door is frozen down to ground. if possible, kick door bottom edge with heel to break bound if you suspect it is frozen to ground.
Posted on Jan 15, 2009
  • 30 Answers
SOURCE: Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Posted on Jan 16, 2009
  • 3197 Answers
SOURCE: Garage Door Goes down 5 inches and then up 5 inches.
Okay here we go.
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these is the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then give it a try.
Posted on Jul 06, 2009
  • 3197 Answers
SOURCE: Have to hold the push button inside my garage to close garage.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
Posted on Jul 20, 2009
  • 3197 Answers
SOURCE: Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Posted on Oct 10, 2009
It's not a remote part that I replaced it's the plastic gear of the garage door on the ceiling of my garage. Now it does not work. Only goes up and down 2 feet when I press the wall button in my gara
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Nov 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have an older craftsman garage door opener that I just replaced the drive gear on. Everything seems to be working properly except that it will not go down unless you hold the button down until it closes...
Oct 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have the Craftsman 1/2 hp Garage Door Opener model 139.53674SRT1. It was working except for needing the main gear changed. Changed the gear and now the opener only clicks and does not actaully open or...
Jan 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
After worm gear repair, the door which is in the closed position ,on activating remote, wants to go down. Then it pauses and reverses a quarter turn. Even disconnected from door it still wants to go down....
Jan 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont move, I just replaced the worm gear inside. Reassembled everything back together and when I put the chain on, it moves down and stops and gets stuck, wont move up or down anymore. Any...
Jan 05, 2011 | Sears Craftsman LiftMaster Chamberlain...
I just replaced the gear and sprocket assembly on my craftsman garage door opener. Now when I hit the remote the motor only moves the door about a foot and then reverses. Any suggestions?
Dec 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Had 1/2 hp sears/craftman chain drive garage opener for a number of years but recently garage door did not open all the way. Discovered worm gear and main gear worn out so replaced them with kit from...
Jan 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Opener goes 12"+/- and then returns
havent heard any of yu say you adjusted the down force.
Jan 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
43 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
