Question about Samsung Q1 Tablet PC
Samsung Q1b on-screen keyboard, turn off
The on-screen keyboard automatically appears on the Welcome screen everytime, and I have no use for it since I have a USB connected portable keyboard. How do I turn off the on-screen keyboard from appearing everytime?
The screen will not power on
If your Q1 won't turn on and the charging light just flickers, most likely you have inadvertently shifted the Hold slider button and your Q1 is on Hold. The Hold function prevents most functions on the Q1 from operating.
To get your Q1 to turn on, shift the Hold slider button so that Hold is turned off.
this button should be on the side of the device
let me know if you need further help
May 12, 2008 | Samsung Q1 Ultra Tablet PC
Our new kindle paper white will not connect to our wifi
The Kindle Paperwhite automatically scans for Wi-Fi networks that are in range of your device. If one networks are found, the device will connect automatically. If a password is required, a screen appears asking you to input that information. Generally, the process is quick and easy.
Occasionally, however, you may need to connect to the Wi-Fi network manually. Follow these steps:
  1. Tap Menu?Settings.
  2. If the network to which you want to connect appears in the list, tap that network.You're finished!
  3. If the network to which you want to connect doesn't appear in the list:
    1. Tap Other.A dialog box named Enter Wi-Fi Network appears, along with the on-screen keyboard.
    2. Using the onscreen keyboard, enter the network name and, if applicable, the password.
    3. Tap the Advanced button.
    4. Work through the series of screens, entering information related to the network, including connection type, IP address, and security type.
      Advance through the screens by using the up and down arrows.
      If necessary, contact the person who set up the network for assistance with filling in this information.
    5. When all the necessary information has been entered, tap the Connect button to join the network.
If your Kindle Paperwhite is connected to your home network but can't connect to Amazon, you may need to reestablish the connection. Tap Menu?Settings?Wi-Fi Networks, and then tap the network that has a check mark to its left. When the Forget Network? dialog box appears, tap Forget. You'll have to reselect the network and enter the password (if one is required).
If you're having trouble connecting to your home network, unplug the Wi-Fi router, wait at least 60 seconds, and then plug it in and wait for the network to restart.
If this does not work....follow this link and do a factory reset.
http://www.wikihow.com/Reset-a-Kindle
Good luck.
Semper Fi,
DrZ
Apr 24, 2017 | Tablets & eReaders
Has software rev 6.3.4. How can I determine whether it needs mandatory software update?
A new, free software update available for your Kindle Fire HD 7" (2nd Generation). This update automatically downloads and installs on your Kindle Fire when connected wirelessly; however, you can also manually download the software and transfer the update to your device via USB cable.
Swipe down from the top of the screen to open Quick Settings, and then tap More.
  1. Download & Install Software Updates Automatically.
Swipe down from the top of the screen to open Quick Settings, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update. After the restart, the message"Kindle is upgrading" will appear on the screen.
Mar 19, 2016 | Amazon Kindle Fire HD
How do I connect irulu usb keyboard to my Visual Land Prestige Elite 7q tablet?
Make sure the tablet and keyboard are charged.
On the tablet, go to setting - it looks like a gear icon. Open settings and about the 3rd item down from the top of the drop down menu, you will see "Bluetooth." Make sure it is set to "ON"
Then go to the keyboard. It also has an "ON" button and press the botton. A tiny red light will blink slowly close to the button. There is a second "Connect" that must also be pushed - it is the "Connect" button and it will search for the Bluetooth signal from the tablet.
When it finds te tablet signal, you will see a message on the tablet screen [it must e turned on} instructing you to enter a 5 or 6 digit code on the keyboard. When you enter the code, a "Connected" signal will show on the screen.
Open a document and start typing!
I'm pretty sure this pertains to all tablets and keyboards.
Feb 12, 2016 | Tablets & eReaders
Tablet wont turn on fully it freezes on the opening screen than just freezes there and wont turn on all the way what can i do to reset it
How to Fix a Frozen Samsung Galaxy Tablet [Solved] - Samsung ...
www.tomsguide.com/forum/id.../fix-frozen-samung-galaxy-tablet.html
2 days ago - 30 posts - ‎27 authors
I have a Samsung Galaxy Tablet that is completely frozen. ... If done correctly thescreen will turn black and automatically start the reboot process. ... Sure have, it won't turn off, swiping the front screen doesn't do anything. My Samsung tablet won't turn on! - Samsung - Android ...
Jan 17, 2016
My Samsung tablet will not turn on. - Samsung - Android ...
Dec 30, 2015
My RCA tablet won't turn on. What do I do? - Tablets ...
Dec 28, 2015
Help! My tablet won't turn on! what do I do?! - Asus ...
Apr 1, 2015
More results from www.tomsguide.com
Jan 21, 2016 | Tablets & eReaders
I have a kocaso tablet. Model #m752h. What settings do I use for the keyboard case?
I am not sure if you need a specific setting to use the keyboard or if your tablet will recognize it once you connect the keyboard to the tablet. To connect the keyboard to the tablet use the USB cable or the OTG cable that came with the tablet. I cannot give you specifics on how to connect because I am not familiar with that tablet, but you can read the instructions in the user's manual of your tablet. I am also providing some links to help you.
How to Connect Mice Keyboards and Gamepads to an Android Phone or Tablet
Connect USB Keyboard on Android Smartphone or Tablet via USB OTG
Clever adapter connects USB accessories to your Android device CNET
Dec 24, 2014 | Tablets & eReaders
How do I connect the keyboard? it goes into the USB port but does not respond or type letters on screen.
normally when you attack a usb device the computer will automatically look for drivers for that machine. What you describe indicates a missing driver for what is attached to the usb lead. Go start ---click on devices click on the new device- double click on the device and then click on properties tab across to drivers and open click on install driver.
Oct 23, 2014 | Tablets & eReaders
I have a samsung galaxy 3 tablet, it has worked fine on facebook u til yesterday. It automatically updated, since them fb dodesnt work, it shuts down everytime i tdy to use it. Everything else works
Press and hold your power button for 20 seconds to perform a soft reset and then turn back on like normal. This will not erase any data from your device like a hard reset will.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_e90a831f4dd5fc5d
Sep 11, 2014 | Tablets & eReaders
Asus manuals
Not seen a manual as such but a dummy or similar guide to Android is likely to have one.
Most android keyboards including jellybean (4.2) are pretty standard.
The up arrow is shift for capitals and hold for a couple of seconds to get all caps rather than one and then return to lower case.
Bottom from right - ?123 is for numbers and symbols and it toggles.
The symbol next to it is for speaking commands rather than type.
long blank is the space bar, then dot,
Left arrow is carriage return or enter. Above this the x with white arrow is backspace delete. A multidot symbol toggles the keyboard on and off the screen.
Normally when you enter a field on a form the keyboard automatically appears. It also appears when you enter a browser address box etc.
Aug 07, 2014 | ASUS MeMO Pad FHD 10 ME302C-B1-BL 32 GB...
Samsung Q1 Tablet PC Logo
543 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
