Question about IBM ThinkPad R30 2656 Notebook
I was installing software on the computer when it froze so shut it down. When restarted it wouldnnt reboot. Error came up 01888: Invalid RFID Serialization Info Area or Bad CRC2
    President:
  • 949 Answers
What software,???
Have you changed the operating system from what the laptop came with.
When it posts see what version bios you have, then go to the website
of your MFG and see if there is a newer version, if you have the newest,
flash the bios to an older one, if you have a older one flash to a newer one.
If you don;t have your manual, get it while you there, are read how to flash your bios very carefully, make sure you know it well before you do this.
You can also try, system restore, or recovery, again, when your laptop
first posts, at the bottom you will see commands, one for enter bios,
boot order, and so on one should be restore or system restore.
The error you posted is a bios error, so it depends if you have changed things or systems.
Try and restore the unit first and see if this works.
Posted on Feb 06, 2010
  • 316 Answers
Hello,it looks like system boards problem that cause bios problem,try to run Bios setup utility and load bios setup default,i think its F10,save and exit.If your problem still occurs go again to Bios setup utility and in general information check if your ram are being recognized and let me know
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
Fatal error 231 on oki c5800 after changing toner, tried power off/on still doesn't work
From the service manual, doesn't look good.
A technicain will have to look at the printer.
RFID Reader I/F Error
An interface error was detected with the RFID reader device.
01 : communication error between the RFID reader and the engine PCB.
02 : the transceiver circuit error of the RFID reader.
03 : communication error between the RFID reader and the Tag chip.
04 : the RFID Tag detection error (more than 4 chips).
If rebooting the machine does not improve the symptom, you need to
check the device.
Mar 08, 2010 | OKI C5800Ldn Led Printer
Ipod froze and tried to be restarted, but it shut down
your ipod has been corrupted,, it has to be taken to the manufacturer to make the software reinstalled,, thank you please rate me,,
Jul 05, 2009 | Apple iPod nano
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Error Message/Black toner empty
Most all new color laser printers employ an RFID reader adjacent to each of the 4 tomer cartridges. There is a unique RFID chip inside (under a small blue slide cover) each toner cartridge. Whan a new toner cartridge is installed, the printer "knows" such and begins a "countdown" of the number of prints that are made which utilize the toner in each of the 4 cartridges. Once a toner cartridge has "processed" the predetermined number of copies you will get a warning that the cartridge is almost empty and must be replaced. After an additional predetermined number of copies are processed, the integral computer within the printer will shut down the printer until the cartridge is "replaced". If you simply "refill" the same or original cartridge and re-install it into the printer, the same RFID chip is in the cartridge and the computer will not reset the print "counter", allowing you to start printing. You have to obtain another couple of new or "re-filled" cartridges (of the same color or black) from an outside source. The printers' internal computer does not keep a complete running list of all of the RFID chips that have been installed and used in the printer (maybe 2 or 3) and then then it is "1st in / 1st out" of the limited RFID memory of the printer. I have been unable to obtain a "Service Manual" for the OKI C3400n printer to determine how to do a "hard reset" of the internal computer. I know there is a way which would allow the "refilling" of the toner cartridges without having to buy an additional 2 of each color.
Dec 06, 2008 | OKI C3400N Single Pass Color Printer
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
1.
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
Install MS office home and student 2007
Reboot
Shut down any active protection software such any antivirus, antispyware, antitrojan, or registry monitoring software.
Try to Unistall by using the install disk. It should detect a previous installation and ask if you want to Install, Repair, or Uninstall.
If that fails, download and run CCleaner - Use the Cleaner and Regisrty modules default settings
http://www.ccleaner.com/
Reboot, and shut down active protection software.
Download and run Windows Installer CleanUp Utility.
http://support.microsoft.com/KB/290301
Remove the applicable entries.
Reinstall
Hope this helps - good luck!
Nov 01, 2008 | 10 10 Computer Network adapter Cable...
IBM ThinkPad R30 2656 Notebook Logo
228 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
