Question about Delta & Single Handle Shower Faucet
We have no hot water upstairs after installing our Delta Leland shower valve. We need to know how to get it to the on/off position because the handle is not on it at this time.
    Problem Solver:
  • 19 Answers
Off should be at the 6oclock
Posted on Mar 02, 2010
I have a Delta scald guard shower faucet (older model). The cold water pressure is good but as a turn to hot the pressure drops to a drizzle. There are 2 other sinks and another shower upstairs and there...
It is more that likely the valve in the stem of your fixture, I'm assuming this is a single handle faucet. If you can replace the valve, you will cure your problem. I am giving you a link to how to adjust the hot water temp.
http://www.ehow.com/how_6531012_adjust-anti_scald-setting-delta-faucets.html
May 10, 2011 | Delta Home
I instslled new delta single shower faucet ,the water is running for 5 to 10 sec even if the shower handle is in off position
Sounds like someone did not remove the plastic valve assembly before soldering the valve body to the copper piping.
That or the valve body needs cleaned out. It is common for debris to get knocked lose when doing installations on old plumbing.
Jan 29, 2011 | Delta & Single Handle Shower Faucet
Attempted to update a single level "diamond" ball shower handle for an older Delta 600 series. Everthing seemed to go well, but when I turned the water supply back on, and when the handle was pointed...
On a single lever shower handle, when the handle is pointing straight down the water is off. The handle will then rotate 270 degrees to the right through cold - warm - hot. What has happened is when you took the other handle off the new handle didn't go into the same position as the old one. So now when the handle stops at the down position the valve is still open probable running cold water. The fix is to take the handle back off. Rotate the valve into the off position so that water stops flowing and reinstall the handle pointing down. Now when you rotate the handle to the right you will get cold then warm then hot at 270 degrees and back to off when the handle is pointing back straight down. If you are still having problems please let me know and we will examine it a little closer.
Jul 18, 2010 | Delta Home
I installed a new Delta shower valve. When I turn the handle to mix the warm and hot water it vibrates like a jack hammer. Is the water presure to high or is the valve bad.
It is due to the water pressure. You may need to install
a pressure relief valve at your main cold water line, so
you can set the water pressure and prevent your valve from vibrating, that is it it is annoying you,.Otherwise,
just let it be..
Nov 10, 2009 | Delta Lewiston Tub & Shower Faucet
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
I installed Delta shower faucet 132900 and I could not shut the water. What did I do wrong?
Did you solder the valve in? If so you may have got it to hot. Or debris could have gotten in the valve. Turn the water off, remove the handle and cartridge. Check cartridge for damage or debris
Mar 03, 2009 | Delta & Single Handle Shower Faucet
Water Temp not hot in shower
you need an allen key to remove the handle once the handle is removed than you need to turn the grey plastic temp guide counter clockwise as far as possible
Feb 01, 2009 | Delta & Leland Lavatory Faucet
Delta & Single Handle Shower Faucet  Logo
153 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
