Question about Hampton Bay 24002 Ceiling Fan
When wiring up the light, blue wire for the light should connect to the black wire in electrical box, correct
Connect white wire from light kit to white wire labeled "for light" then connect black wires from light kit filter to blue wire from fan. Use wire nuts to make the connections
Posted on Feb 09, 2010
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Nov 11, 2017 | Dryers
Ceiling fan and light kit installation 4 wires 3/1 (red, black, white) from electrical box to 3 wire (black, white. green) from fan. How do the wires connect?
I'm assuming from your question the 4th wire in your electrical box is a bare copper wire which is the ground. The green wire gets wire-nutted to that. The white wires get wire-nutted together. I'm guessing you have two switches installed in the wall for the fan because there is a black and red wire coming from your electrical box (one for the light and one for the fan) connect the two black wires together. The red wire is then connected to the blue wire in the fan which is the light.
Dec 22, 2016 | Dryers
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
My wall box only has a black & a white. Can I still use this timer?
You posted under GE 15069.
If you have different timer, then add a comment.
Yes you can use this timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15067
Here are wiring instructions
Timer might have blue wire instead of red wire.
Some timers do not have green wire.
How to wire this timer:
1) Green wire connects to bare copper wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This will power timer electronics.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
do-it-yourself project.
Jan 13, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Timer has 4 wires Blue, Green White and Black but wall switch only has black and white. where do I connect all the wires?
You are replacing a single-pole switch that has two wires.
You posted under UPM timer.
But UPM timers have a red wire instead of a blue wire, so you have different brand.
Some GE programmable timers and some Leviton timers have a blue wire.
Here are instructions:
-Green wire goes to bare ground wire.
-Timer black wire goes to black wire
-Timer blue wire goes to white wire.
-Located in back of electric box are white wires twisted together and covered with wire nut. These are neutral wires. Timer white wire connects to these wires. This will power electronics inside the timer.
-If your box does not have white neutral wires described above, then connect timer white wire to bare ground wire along with timer green wire.
-Turn power ON, and push on-off button. If timer works, then it is wired correctly.
- If timer doesn't work, then reverse Timer blue and Timer black wires.
- If lights blink on-and-off, then you connected white wire incorrectly, review wiring shown above.
If your box does not have neutral wires or bare ground wire as described above, then buy Walmart.s Brinks 46-1022 or Intermatic ST01C or Intermatic EJ500 or Aube T1032. These timers do not need neutral or bare ground wire.
Dec 31, 2010 | UPM Programmable Wall Switch Timer
I have a ge digital wall switch mod 15265 My wall box only has a white (hot) and black (neutral) wires When I connect up the wires - black on switch to hot and both blue& white on switch to neutral -...
First of all the National Electrical Code states that your black wire should be the hot and the white the neutral...the black on the switch goes to black in the wall...the white to the white...and the blue wire should be the switched lead that goes to the light
Dec 23, 2010 | General Electric Hardware & Accessories
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
When I press the timer to go on my three outdoor lights go on and off, timer clicks that way too
Timer is wired incorrectly.
1) If you have battery-operated Intermatic EJ500 or ST01C, with red, blue, black and green wires:
Then red wire is where blue wire should go. Swap blue and red wire.
2) If you have Aube battery-operated timer, add a comment and say if you are replacing single-pole or 3-way switch. And say where each wire is so far.
3) If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
Dec 11, 2010 | Woods Hardware & Accessories
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
Does the blue wires connect to the black or white wires? I cannot find the instruction booklet. Thanks
Hi, At the fan you'll have a black wire, blue wire, green wire and white wire.
In the ceiling you'll have a black wire, a white wire, and a bare copper wire. If you are using the same wall switch to turn on all of the power to the fan AND the light, connect as follows:
White at ceiling to white from fan
Black at ceiling to black and blue together from fan.
Bare copper wire at ceiling to green wire from fan.
When connected like this, the main power is from the switch, and the fan and light may be set by the pull switches on the fan.
Best regards, --W/D-- Please feel free to rate this solution... thanx!
Aug 03, 2009 | Casa Vieja Endeavor Cherry Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
351 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
