Question about Samsung SGH-X820 Phone
I plug the charger in but there is no response of the battery being charged. Can anyone help?
    President:
  • 1,561 Answers
I suggest you test your charger with another similar phone like yours, if it charges with another phone, it means the charging port of your phone is bad and need to be replaced.
But if it did not charge the similar phone like yours, it means the charger is bad and need to be replaced.
I wish you best of luck.
Posted on Feb 06, 2010
Can anyone tell me what and where this plugs into. 2003 Honda shadow 600 vlx.
Looks like a battery charger plug (for trickle charging off-season). Does it always have 12v across the terminals? If so, it's a battery charging plug.
May 18, 2015 | Honda Motorcycles
96% plugged in, not charging Hi all, my Asus
Laptop battery do have a specific lifespan, specially for older units. Still, you can check that your charger are working properly, using a voltmeter (do check the outer label of the charger for actual voltage output).
You may try to do my Tips on Laptop battery
Good luck
Tedmac
Oct 17, 2013 | ASUS Computers & Internet
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
May 29, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
TX IS DEAD
The T3 will appear dead until the battery has SOME charge. A totally dead battery, even though plugged into a charger, will not let the T3 turn on. You mention a previous charger problem. Could be a bad charger, or a bad battery. Check to see if the charging light is on on the T3 when you think you are charging. If it is not on, try another charger. If it is on, you may have a bad battery.
Jim
Sep 09, 2008 | Palm Tungsten T3 Handheld
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
Jazz DV169 issue
umm i have jazz camera and i didnt have a charger **** i bout a motorola house cahrger and it charged my camera.
Aug 01, 2008 | Jazz DV169 Camcorder
Will not charge at all
will the unit power off the two adapters. Ie when you remove the battery will it still power up? If it doesn't you have a bad charge jack. If it does you have a bad battery.
Oct 25, 2007 | Sony Ericsson T610
Samsung SGH-X820 Phone Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
