MY MODEL R52WH74 MADE SEPTEMBER 2006 HAS DEVELOPED A CONVERGENCE PROBLEM TODAY. THE SCREEN IS BOWED AND THE COLORS ARE SEPERATED. WHAT DO I NEED TO DO AS THE CONVERGENCE OPTION IS NOW GONE FROM THE SETUP SCREEN?
HDTV GURU
  • 261 Answers
SOURCE: ?Convergence problem
Sounds like the convergence IC'S are either bad or a fuse maybe bad in the convergence circuit. The part # should be on the chip itself if you want to try and change them yourself. Good luck and keep me up to date on outcome. Cheers. Jay
Posted on Feb 09, 2008
  • 85 Answers
SOURCE: i have a rca r52wh74
The 45 volts feeding the convergence amp power supply may be missing that is why convergenc is bad the heat sinks on the convergence amp cba are probably cold from not running that is why convergence is not displayed in the menu repairing the power supply will most likey fix it for you I assume you have a schmatic?
Posted on Aug 31, 2008
  • 1030 Answers
SOURCE: Autoconvergence option is GONE!
i see this so often i have wrote a tip and tricks instructions. see fl231 problem under tips and ticks in my profile. if u can solder it a simple inexpensive repair
Posted on Sep 27, 2008
ginko
  • 19396 Answers
SOURCE: RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Posted on Dec 13, 2008
  • 1030 Answers
SOURCE: Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Posted on Mar 15, 2009
The colors are seperating and screen picture is bowing in?
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Colors seperating and Screen bowing
The convergence circuit is not working. There are bad solder connections on the sweep board and a small fuse is open. this is not easily done yourself unless you have a technical background but an RCA tech can fix this easily.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color is seperated
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Mar 15, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Mar 09, 2009 | RCA R52WH73 Projection Television
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT 47WX51 TV troubleshooting
  • Screen looks 3D
Mar 25, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
