My hotpoint fiest edition washer will wash , but it wont spin at all . Any help would be deply appreciated .
  • 56 Answers
Check your lid switch
Posted on Feb 07, 2010
Testimonial: " thanks ."
Washer won't agitate it does spin the clothes
Hi
If Washing machine wont agitate there are several reasons that causes such problem,please check the bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntagitate
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint VWSR4150B Top Load Washer
I have a hotpoint wma22. problem with it does not spin.The belt is ok .
+I would remove the motor and check the brushes for wear.
If they are less than 3 or 4mm long, thet need replacing.
If brushes o/k, then it is probably a control module fault.
I am of course assuming that the washer has drained the water out, or it will not spin.
Jan 12, 2010 | Hotpoint First Edition WMA22 Front Load...
Safety catch wont release after 2 minute swtch off.
hi there......sometimes this can be solved by reeating the spin cycle again....the door switch requires replacing
regards Sir Galahad
Aug 16, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition washing maching won't spin
hello any spin problems could be down to the module circuit board
shaun
Aug 02, 2009 | Washing Machines
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
The water will not drain on my first edition wma 10 hotpoint washing machine so does not spin either any clues to where the filter is???????
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
Jan 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Drum wont turn
check for worn carbon brushs in the motor.good luck!
Dec 01, 2007 | Hotpoint First Edition WMA20 Front Load...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
