Question about GE WDSR2080D Top Load Washer
Basket has become unstable and seems to have come off of the support/stabilizer at the bottom. which causes it to thrash around during spin cycle.
  • 56 Answers
You might have broken the hub. is there little pieces of blackish grey metal on your clothes? if so that could be your problem. the hub is covered by the base of the agitator, remove the agitator by pulling it up (it is very tight) starting to fill the tub with hot water will help to remove it
Posted on Feb 07, 2010
Where is my suspension spring on my washing machine
The suspension springs on your washing machine are used to either suspend the tub assembly from the cabinet or to stabilize the tub assembly to the washer base. They also absorb the vibration of the wash basket while the machine is in the spin cycle. Occasionally these springs will become damaged, stretched or detached which can cause excessive noise and vibration from your washer during the spin cycle. You will need to remove the top or front panel of the washing machine to gain access to the suspension springs. Inspect for stretching or damage and ensure that they are securely attached at both ends. Use caution when replacing the springs as they are under tension and always wear the proper protective clothing. We recommend that you replace all of the suspension springs if any are determined to be defective.
Jan 13, 2017 | Washing Machines
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
The washer is 2.5 years old. The Basket has no stability during the spin and wash cycle. The basket bangs against the side of the machine and the machine bounces around the laundry room moving sometimes...
they do dance well dont they? this is caused by the support springs coming off the drum holder and the drum will have droped a little as well,
take off the top of the washer and look down each side you should see the support springs if the off just hook them back on or fit new one's?
dont leave this as it will pull all the pipes off inside the washer
its an easy fix,
Aug 09, 2010 | GE Energy Star WCVH6260F Front Load Washer
My admiral washer ATW4475TQ0 makes a thumping noise at end of spin cycle and when lid is opened during spin. What could be wrong?
there are stabilizers on the drum if they have fell off or broken away the drum will swing wildly around on spin this will cause the drum to "hit" the inside of the washer,,,check the drum stabilizers are in good order
Aug 08, 2010 | Maytag Washing Machines
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Fwt449gfs1 unbalanced in spin cycle
there is a three post bracket bolted to the back of the inside drum. on ours two of the three spokes are broken. looks like you have to buy whole new drum assembly. around 300 bucks
May 21, 2008 | Frigidaire FWT449
Spin cycle
This is a repeat, but maybe the same result.  Remove the front cover (usually two clips between the top and the front, move it around) and check each of the springs that hold the unit to the base.  Have found that just one spring would cause a out-of-balance condition.  When you open the lid, does the basket seem to be leaning one way or the other?  If so, look on the side that shows more than the other.  Also, reach in and grab the inner basket to see if it seems loose.  Have had the basket drive mount break halfway through and caused it to roll really bad.  Let me know what you find out, or if you need futher help.  Jim
Oct 15, 2007 | Maytag Performa PAV2200
Thrashing Spin Cycle
If the basket is loose, you will have to replace the basket( this includes the spider arm you are asking about) and the rear half of the tub( this includes the bearing). Be sure to check the owners manual for your warranty information. The basket and tub may very well still be covered by warranty. You will have to pay the labor, usually around $200.
If you do decide to purchase the parts and repair it yourself, post back and I will try to walk you through it.
Just remember this,
 it is much easier to remove the inner workings from the rear than the front, and
this is a 2 man job.
1 person can do it but it is sooo much easier with some one to help set the tub assembely out as a unit.
Oct 10, 2007 | Kenmore 43042 Front Load Washer
GE WDSR2080D Top Load Washer Logo
119 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
