Question about Panasonic KX-T7453 Corded Phone
Can I plug a kx-77453 into a regular outlet. The one I have was part of an 5 phone system I had in a business.
4 Suggested Answers
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
  • 225 Answers
SOURCE: I used to have the Panasonic KX-T7630 system in
The KX-T7630 is a proprietary digital phone that will only work on panasonic phone systems. You need an analog phone if you are going to connect it directly to an outside telephone line.
Posted on Jan 19, 2011
cnavarro
  • 2460 Answers
SOURCE: I bought five Panasonic KX-T7730X
A TD system is a DIGITAL phone system and the 7730 phones are ANALOG. I don't know what X means, but I guess they're not from the US :-). Anyway, the ANALOG phones need 4 wires to work, instead of the 2 that the digital phones have. If your installer was lazy and didn't cross-connect 4 wires at the frame or put in 4 bridge clips on each jumper, then you don't have a voice path. Or, XDP is turned on and you'll have a bit of a problem.
If you have an IM and a PM for the TD system, you can find the wiring diagram and the instructions to read the XDP status. Quick answer is the first 2 of every 3 pairs will run to your phone. If you start with a digital phone in the port first, turn on XDP and plug a single line set into the XDP port, you will get dial tone (may have to dial 390 or 391 to enable/disable the XDP twinning) and that dial done will be different from the digital phone. If you don't get dial tone, your first pair wiring is missing. Fix that, turn off XDP and you 77xx series phone will now work in the port.
Carl
Posted on Jun 24, 2011
I want to use my panasonic kx-t7730 system as a EAVESDROP system. can you help me please?
To listen in on someone's call you enable monitor in COS and dial a busy phone and press 5 to listen in
Oct 04, 2013 | Panasonic KX-T7730 Corded Phone
My Matag RefrigeratorTrips the Ground Fault
Most likely a problem with the GFCI outlet itself. Sometimes their internal reset mechanism gets weak and they need to be replaced. A new $10 outlet and about 5 minutes time and you should be back in business :)
Good luck,
Boone
May 24, 2012 | Maytag Matag 25.6 Cu Ft Side By Side...
Panasonic kx-t7453 corded digital super hybrid system How do I turn my voicemail box on so a caller can leave a message at my extension? thank you
Pretty much, it depends on what happens when you dial 165. That's the voice mail access number for a Panasonic TD phone system with Pana VM. If you get the voice mail lady, set the box up and then from the intercom dial 7102/3/4/5 where 2 is all/3 is busy, 4 is no answer and 5 is busy/no answer and 165 or whatever the VM access number is and possibly # (I forget if it's required). That will light the FWD/DND light and send calls to the voice mail system.
Carl
Mar 11, 2011 | Panasonic KX-T7453 Corded Phone
My Phone model is Panasonic KX-7250X How do you forward incoming calls to another extension
Forwarding is 710x plus the extension, where x is 2 for all 3 for busy 4 is no answer and 5 is no answer/busy.
These are the TD system forwarding commands.
Carl
Feb 22, 2011 | Panasonic Lands Phones
I used to have the Panasonic KX-T7630 system in the office building we sold. I no longer have the capability of setting the entire system up - is there a way to use the phone as just a regular desk phone...
Jan 19, 2011 | Panasonic KX-T7630 Corded Phone
Panasonic Kx-tea 308 low volume problem, using kx-t7730 and kx-t7720 handsets, low volume on all handsets, both sides of conversation. Panasonic sent new pc and handsets shortly after system was...
If you have to eat the system, I'd suggest butter, salt and pepper LOL
Seriously, what happens when you plug a regular phone directly into the outside lines? Or, better yet, plug a regular phone into jack 01 and TURN OFF THE POWER on the phone sytsem.
Now you have a phone wired to the outside line. If you can hear on those, then you may have a line current issue, or something else. If you can't, the telco is obligated to give you a line you can hear on. If they can't deliver, try an alternative like Vonage.
Carl
Sep 30, 2010 | Panasonic KX-T7730 Corded Phone
HOW TO LEAVE A VOICE MESSAGE ON A PANOSONIC kX-t7636
Your VM has an extension, usually 165 or 500. You forward your phone to Voice Mail by dialing *710x 500 # where x is 2 for all calls, 3 for busy, 4 for no answer or 5 for NA/Busy. I use 4.
The FWD/DND light will blink and the display will say Call FWD (condition) 500.
Now, all calls, both from the inside and outside will forward to the voice mail system.
Carl
Apr 15, 2010 | Panasonic KX-T7636BK Digital Telephone...
Two phonelines no longer accessible. Using Panasonic KX-T7730 with a Panasonic KX-TES824 system. Lines were working fine and have now disappeared. They don't ring in and I can't ring out on them. ...
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Oct 09, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
