Question about HP DeskJet 5150 InkJet Printer
I used to clean the printer heads all the time but now they're dirty (obviously...black lines randomly all over my page) because I just put in new ink but I can't see to find where to do this in the new Windows 7 I've just installed....
  • sandstars200 Feb 06, 2010
    There used to be a way to make the PRINTER do the cleaning for me and it worked beautifully....
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
  • Rylee Smith
    Rylee Smith Feb 06, 2010
    This is another way to clean the print head, please try this out its a simple way to do cleaning of your printer. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Black lines on print, new printer
Go to the settings on your computer hit properties and do an alignment, sometimes if you take out the ink cartridge and put it back in it will say do you want to do an alighment, then after the page prints you have to scan it, then pick which one looks the best
Jan 28, 2014 | Canon PIXMA PRO-10 Professional Photo...
The new #5 black cartridge prints an almost solid quarter " line over everything. I bought another new cartridge and it did the same thing. I've had this printer two years and have not had this problem...
Hold the resume/cancel button in until the LED blinks twice. This should print out a test page. Is the line still there? If no, try a different USB port, or reinstall your printer driver or try substituting your USB cable.
If yes, try this: open the lid, when the head moves to the center unplug the power. Remove all the ink, lift the lever on the head and remove the head. On the back of the head are small contacts. Make sure they are clean. You can use a soft cloth and a dab of windex on the cloth to gently clean the contacts on the head.
Inspect the bottom of the head. It may be pretty dirty with ink and other stuff (dust, hair, ashes). If it is, you can clean it but you must be very gentle. A good trick is to put some hot water in a saucer and set the head in the saucer for a few minutes. It's important to only get water on the bottom surface of the head (where the dirty ink is). After soaking, gently pat it dry with some paper towel or a soft cloth you don't mind getting dirty. Inspect it again. If you see any scratches on the bottom of the head it may be the cause of the problem. Reinstall the head in the printer and reinstall the ink cartridges. Plug it back in, turn the power on and retest it. If the printer still has the line, you may have a bad head. In a small number of cases this can also be caused by a bad board in the printer. If you decide it's definitely the printer after cleaning the head, you can either check if you have a local Canon service center or you can check into replacing it.
Oct 07, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Black lines across the page
hi there,
unplug cartridges and check its heads are clear if not take a tissue paper and cleane it very gantelly, intall the cartridges and run cleanning test from printer properties.
Jul 11, 2010 | Lexmark X2600 InkJet Printer
Printer is printing out with lines in the text.
Sounds like the head is dirty. You need to run the printer through the cleaning cycle a few times.
Nov 27, 2009 | Office Equipment & Supplies
Black horizontal lines
Put the old cartridge back in. Print a page. If the lines go away, get another cartridge.
Oct 15, 2009 | HP LaserJet P3005n Printer
Printing
Your print head may be dirty. Remove the ink carts and examine the print heads.
You should also examine the printer for a printer head parking location or cleaning pad (usually off to one side, where the cart sits when not in use or there is a pad on the side to use in cleaning the print head.)
If the print head is dirty, clean it with a soft cloth.
If the landing pad or cleaning pad is dirty from a leak, you may need to remove it or replace it.
Does printing sound normal? It is also possible that worn rollers may cause the page to advance incorrectly.
May 06, 2009 | Lexmark X7350 All-In-One Printer
Epson RX500
Are the lines ink? Either you have to keep cleanng the heads until they work correctly or find out where the ink is coming from, if not from dirty heads.(dirty heads means that the ink had drived and you may have to remove them and clean them with rubbing alcohol . What color are they? Replaced any of the ink  cartridge yet?
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=26321&infoType=Overview
Apr 04, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson stylus c66
Take the cartridge out and put it back in then try to print, if it is still the same
try cleaning the print heads>control panel>right click on c66 and go to printing
preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Nov 24, 2007 | Epson Stylus C66 Inkjet Printer
HP DeskJet 5150 InkJet Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
