Question about Studio Projects T3 Professional Microphone
Want to replace bad tube... suggestions for replacement? Mic is noisy from time to time, and I'd like to put a great sounding tube in it to replace what is there.
    Champion:
  • 211 Answers
When I have to replace a tube into studiomics, I'm always using Groove Tubes.
In your case you need a 12AY7 or 6072.
Regards,
Gerard
Posted on Feb 06, 2010
Getting alot of static through my mic
I own two MXL 990's and have had no issues with extra noise of any kind. I would suggest checking or replacing the mic cables with new or known good ones. Also I don't know what you are connecting it to but a weak or noisy Phantom Supply could also cause extra noise.
Mar 08, 2014 | MXL 990s Professional Microphone
When I start the van, sometimes I get a cranking sound. People tell me its the lifters where the oil passes through. I put in some oil detergent for noisy engines and it works, but then it comes back...
First thing to do is remove the oil pressure sending unit replace it with an oil pressure gauge. If the oil pressure is okay 30 to 40 lbs. idling and 40 to 60 at medium rpm, then you may need to adjust the lifters if that's what you're hearing. Lifters make a clicking sound at half the engine speed, and they do not make any heavy metal noise like a rod or main bearing will. Usually, by the time the lifters are badly worn the engine is due for an overhaul or replacement. Also, it's futile to just replace the lifters because if they're worn out I guarantee that the camshaft is too.
Jul 01, 2011 | 1998 GMC Safari
2002 ford escape xlt FWD rear hatch is extremely noisy. How do I adjust or fix? Some times intermittent. Overall sounds loose. Have tried to adjust stricker on glass seemed to help. Dealer fixed once under...
Get some dielectric grease and put it on the latch located on the bottom of the hatch. You will need to put quite a bit of grease in there and make sure you get it right inside the latch. Use the dielectric grease that comes in the squeeze tube not the spray can.
Apr 06, 2010 | 2001 Ford Escape
I have a 1950s Montgomery Ward tube amp -- same model as Silvertone 1432. This 10-watt amp suddenly doesn't have any sound out of the mic input jack. Sounds fine in all other input jacks. Could it be a...
There is a or should be a 12AX7 preamp tube driving the microphone side of the amp. That tube could be bad, they are only about 15 to 20 dollars for a new one, don't worry about NOS stuff, waste of money if you ask me. Tung Sol makes good 12AX7s. Also check the volume control. Spray it out with some contact cleaner and rotate the control about 10 times, this will get rid of any dust or oxidation that has occured over time.
Since you don't get any sound it should be just a tube replacement.
Dec 15, 2009 | Washburn Amplifiers: 25 WATT Guitar...
GE SpacemakerXL Microwave Model JVM1450 It's been working great. Then put somethingin,turn it on. It ran 30sec. made a growling sound,like it was straning or slowing down,then Blew the fuse.I replace the...
SOUNDS LIKE MAYBE HIGH VOLTAGE RECTAFIER SHORTED MIC ARE VERY DANGEROUS THEY HOLD VOLTAGE EVEN WHEN UNPLUGED YOU MAY CONSIDER PRO ON THIS SORRY
Nov 06, 2009 | GE Microwave Ovens
Want to replace PX100 wires
Just be careful, maybe try to find a guide to dissasembling the PX-100's - I had a pair go bad that I tried to open up and I mangled them somewhat - of course I wasn't being super careful, nor were they in great condition at that point. There's a lot of you tube vides about replacing the ear buds with other ear buds - it should be straight forward, minus the extra care for taking the PX-100's apart. Any concerns about impedance matching for the wires? Could this represent a degradation of the PX-100's sound if the wires are diff. impedance?
Jan 07, 2009 | Sennheiser PX 100 Consumer Headphones
Toshiba CF36G50 Noisy when you turn it on
that sound is comming from the tube anode it is leaking you have to discharge the high voltage from the anode cap,then take off the cap clean the area with alcohol and put some red or clear silicone on the cap and anode connection replace back the cap on the tube leave to dry for about half hour,this will remedy your problem,no more static.good luck.
Jul 05, 2007 | Toshiba CF36G40 36" TV
Z-2300 noisy speaker
ur speaker is bad probebly torn membrane try replacing it (or disconnecting) this speaker there is a special kind of glue for membranes .... try it good luck windman
Oct 26, 2005 | Logitech Z-2300 Computer Speakers
Studio Projects T3 Professional Microphone Logo
115 people viewed this question
Top Studio Projects Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Studio Projects Audio Player and Recorder Expert? Answer questions, earn points and help others
