Question about Uniden PRO510XL 40-Channels Base CB Radio
My uniden pro510xl when hooking it up imediately blows the fuse like a dead short but if i hook up another radio it will work fine
  • 56 Answers
The radio was probably wired backwards at some point. There is a reverse polarity diode inside that must be replaced to fix this. If you have continued replacing fuses and plugging it back in, there may be further damage such as finals or audio amplifier chip as well. you will need to take the radio to a qualified repairman for service. If it is simply the reverse polarity diode, your bill should not be more than an hour's labor charge.
Posted on Feb 12, 2010
I have the Uniden PRO 510xl has been working good for over a year but after setting for the winter when I ask if "anyone has a copy on this radio" I hear a response but can not understand even after adjusting the squelch at different settings and the S/RF is peaked.
HELP
Posted on Jun 01, 2011
Pro510xl schematic
do a search for it. uniden pro 510XL schematic. I found it.
Oct 23, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
How to add talkback to a uniden pro510xl
68 to 200 ohm resistor to the postive side of the speaker to board ground
Jan 28, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
My radio would not turn on yesterday. I have checked the fuse and fuse connections. The fuse was black, so I put a new one in. The fuse connections were good. The connections to the battery are good, the...
The black fuse means it blew from a fast, heavy short circuit instead of an overload of some sort. The high current vaporizes the wire inside and coats the glass, giving it the black look. In an overload, the fuse link melts.
A common cause is failure of the reverse-polarity diode in the radio. It's there to cause the fuse to blow if you get the battery connections backwards when hooking up the radio. The diode can short, and this will cause the blown fuse. If you check the fuse and find it's black again, you should check the diode with an ohmmeter. Look for the diode near where the battery lead connects to the circuit board in the radio.
Aug 02, 2011 | Uniden Solara - VHF Marine 2-Way Radio
I just have uninden pro510xl (used), but don't know how to set the channel (progamming) so it can match with my handheld radio (i use motorola GP200). Thanks...
hi The uniden pro510xl operates on 11mtrs or 27mhz (cb band) the gp200 is vhf 136-174mhz so you will not be able to communicate through these radios you can only program within the specified frequencies hope this solves your problem
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My uniden pro510xl transmitts slightly off frequency. Is there an adjustment for this?
Yes, you need a frequency counter to get IFfreq back were it needs to be. google cb shops in temple, tx
Aug 07, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I have a uniden pc68ltw cb radio and it keeps blowing the 2amp in line fuse i tried a 5amp but still blows the fuse.i hooked it into another truck to test it but still blew the fuse. something wrong with...
have you been using the uniden pc68ltw cb radio without the fuse blowing before?
If the uniden pc68ltw cb radio has not been blowing fuse before, then might be a problem from the radio. This problem should be a power related problem.
The fuse blowing means there is excess of current. So while your trying to refuse, thicken the wire.
Best regards.
Feb 23, 2010 | Uniden Radio Communications
Uniden PC66a CB blows fuses upon installation
yes the problem is a diode on the input of the rig. this is black with a silver band at one end it will need replacing as it has shorted out.
Aug 05, 2009 | Radio Communications
Uniden 520xl makes humming noise when mike is keyed
if you have a power mic , you might have it turned up to high. next make sure you have a good ground on your antenna. if that is ok and you still have the same problem have the swr checked. this should fix the fm radio noise.
Apr 10, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
1987 uniden pro 510 xl
Wow, from what you are saying, you should not be messing with the insides of the radio. Finals, are not resistors, that are TRANSISTORS, and they do not have resistance values at all.
The final is the little black transistor attached to the heat sink at the back of the radio. You can't just change the final. there are other parts that need to be changed if you want to do a high power mod. Don't even mess with it. you don't need too.
Next, D14 is not the uniden model. thats what you mess with in a cobra. Don't cut d14 in that radio or you will prolly blow it up. The diode you want to cut out is D203. DON'T CUT IT!!, Just un solder one leg of the diode. You won't be over modulated. That will bring you modulation up and your peak watts. it will swing to maybe 15-20 watts peak. That alone with make the radio louder.
You really don't need to raise the dead key. With a lower dead key you have higher swing. Its all about the audio. 2 watts for dead key is fine. Thats what I run.
You cannot do any other peaking with out a meter. If you have a meter you can spread the 2 coils behind the large transformer a tiny bit until you have peak wattage. L201 and L202. but from reading what you said, you should probably leave them alone, you will gain only a watt or 2, and its not worth it if you mess it up.
To be honest with you, all you really need to do is unsolder one leg of D203. Make sure you pull the leg out, and make sure it is not touching anything so it will not short.
Now if you do this, and it splatters, you can always solder it back in, and then turn RT201 all the way to the right, I think. If you turn it all the way to the right, and there is not modulation, you just turn it all the way to the left.
Please don't mess with anything else or you will screw the radio up.
Mar 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL 40-Channels Base CB Radio Logo
272 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
