Question about Xerox Phaser 8560N Laser Printer
Xerox Phaser 8560 error: 08.007.41:26. there's grinding right before I get this error. Any ideas?
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
  • 117 Answers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Posted on Apr 07, 2009
  • 17 Answers
SOURCE: xerox phaser 8560 close control panel error
Bad control panel. Xerox will replace for free (800 635 8100) call and ***** to get it for free (They had a "LOT" of defective panels)
User installable.
Posted on Aug 21, 2009
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
darkpain
  • 316 Answers
SOURCE: xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Posted on Feb 04, 2010
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560DN Laser Printer
P/N FOR pHASER 8560 DISPLAY PANEL
P/N for Phaser 8560 printer is 802K93650
Apr 21, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8560N Laser Printer Logo
301 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
